*******GSR BOOST LAG? RPM STUDDER*********
Old Nov 6, 2011 | 09:45 PM
TurboCivicR93's Avatar
Default *******GSR BOOST LAG? RPM STUDDER*********
Okay so everytime i hit over 3k engaging boost with the gas firmly pressed the car struggles to get up kinda studders, also has a weird rpm shock the gauge goes nuts. i have no clue what it could be, i have external msd blaster ss coil with stock gsr dizzy with msd cap, plugs and ngk bkr7e plugs gapped at .22
car used to studder with stock coil nut the rpms wouldnt do what it does, now the rpms studder with the external coil, hoping it could fix the problem but it didnt.
anyone got any hints on what it could be? thanks in advance
Old Nov 13, 2011 | 01:06 AM
Default Re: *******GSR BOOST LAG? RPM STUDDER*********
anyone? i will upload a video showing what the rpm does soon.
Old Nov 13, 2011 | 06:07 AM
TheShodan's Avatar
Moderator
That would be best.
Old Nov 13, 2011 | 11:23 AM
shanebadoo's Avatar
Turbo civicr93, please describe your setup. Not only poor/weak ignition causes studder. Mismatched parts can cause those problems you are describing.
Old Nov 13, 2011 | 11:30 AM
komat's Avatar
is the car tuned?
Old Nov 13, 2011 | 01:32 PM
GSR b18c1
@ 7lb of boost
ITR LSD tranny
skunk 2 pro series intake manifold
hks bov
greddy 18g dsm turbo w/ greddy exhaust manifold + downpipe
dsm 440cc injectors w/ comptech fuelrail
skunk2 stage 1 cam shafts
turbo timer dont work anymore so i jus wait in the car before i shut off, every 40 sec
stock gsr dizzy w/ msd blaster ss external coil,
also HAD the MSD 6a running but somehow doesnt work anymore, dk if the box itself needs to be grounded. but thats the only change i did so far besides replacing the whole dizzy.
car is tuned on chrome fr 10lb of boost, only running 7lb so far, its safe but jus burns alot of gas.
im thinkning it could be the spark issue, to much fuel, little spark even with the external coil. i dont want to mess with it cuz i dont want to make it worse.
going to try to upload video today
Old Nov 13, 2011 | 10:43 PM
http://www.youtube.com/watch?v=3sfuZ5Cuisk
heres the video of 5th gear, it does it in all gears but i was on the freeway.
video shows me driving normal then when i firmly step on it, watch the rpms i have so much HP loss
Old Nov 13, 2011 | 10:55 PM
komat's Avatar
looks like a poor tach signal from the dizzy
Old Nov 14, 2011 | 06:32 AM
thats what i was thinking but you think that could also drop my horsepower? and make the car sound like its getting maybe too much fuel than spark, or the otherway around.
Old Nov 14, 2011 | 07:12 AM
mayfly's Avatar
this answers your whole question. if you tuned with it then it could be the problem. i was giving the motor that more output of voltage before, but now you dont have it. im not really explaining it well so just check out this link. the first page under THEORY : http://www.msdignition.com/uploadedF...structions.pdf
Old Nov 14, 2011 | 07:13 AM
mayfly's Avatar
it also works with your tachometer, it has a setting on it so it could be whats messing with the tach as well
Old Nov 14, 2011 | 08:49 PM
thats exactly what i was thinking. to fix the problem i maybe need to gap the spark plugs less? or get another 6a box ?
Old Nov 15, 2011 | 05:07 AM
kbouchard1092's Avatar
Or you could just convert back to OEM cap and coil, since aftermarket ignition is not needed in youre set-up. I had a MSD box and blaster 2 coil. All that thing did was give me problems and got less then 1000 miles out of it trouble free. Went back to OEM and never had a issue. You're gap of .022 is good if you switch back to OEM. Most people i know dont upgrade ignition unless there well over 500whp...
Old Nov 15, 2011 | 05:35 AM
kyden's Avatar
you should go back to oem ignition. i am at .030 and have no blowout.
Old Nov 15, 2011 | 06:10 AM
i was OEM till, it was "lagging"/"spuddering" worser then it is now, but the rpm gauge wouldnt go all haywire as it shows in the video, so maybe 0.22 is to big for OEM, or maybe when my car broke down and had used another OEM dizzy for awhile it prob burned out the electrode and exposed my gap alittle further, ima check it after work. but thats what ive been hearing alot about msd, no way in hell my car is over 500 whp.... yet
Old Nov 15, 2011 | 06:12 AM
i have the 6a model, the 6al model is the one that works with my tach.
Old Nov 15, 2011 | 06:45 AM
You shouldnt have any issues with oem at youre power levels.... i have zero issues and run much more boost/power. Even at .030 you shouldnt have blow out at 10psi...i never had a issue until after 15psi then reduced it too .022-.024 and again no issues since.
If its feeling laggy with oem ignition compared to msd i would look into getting a re-tune. Change it back to OEM and spend the money to get a re-tune. That will solve all youre problems
wantasol
Jul 28, 2009 03:32 AM
b18psi
May 11, 2004 01:06 PM
TurboB18C1
May 8, 2002 09:57 AM
SiRkid
Oct 31, 2001 01:16 PM
mod5
Sep 11, 2001 06:46 PM
