what ignition for boost?
Old Oct 30, 2001 | 06:36 PM
SiRkid's Avatar
Default what ignition for boost?
goin turbo.
what ignition do you recommend?
thanks
Old Oct 30, 2001 | 07:46 PM
WykidEH's Avatar
Default Re: what ignition for boost? (SiRkid)
You know, MSD. . . . . .
Old Oct 30, 2001 | 08:48 PM
BoostinDC2's Avatar
Default Re: what ignition for boost? (WykidEG6)
MSD digital 6 plus with the SS coil
Old Oct 30, 2001 | 08:56 PM
Anthony K's Avatar
New User
Default Re: what ignition for boost? (BoostinDC2)
Why not stock?
Old Oct 30, 2001 | 09:51 PM
98hx99b18c's Avatar
Default Re: what ignition for boost? (Anthony K)
Stock!
Old Oct 30, 2001 | 10:28 PM
Incognito's Avatar
Default Re: what ignition for boost? (98hx99b18c)
Stock ignition, if it's for a street car. Should be enough. I hear a lot of people having problems with MSD ignitions.
Old Oct 30, 2001 | 10:30 PM
Anthony K's Avatar
New User
Default Re: what ignition for boost? (Incognito)
Yup, my stock engine 97 gs-r runs great with the stock ignition at 7psi of boost. Plenty of other people do the same.
Old Oct 30, 2001 | 10:43 PM
BluePrintmfg.com's Avatar
Banned
I recommend msd ignition, to prevent bad spark and many more problems, also would go with apex electronics product to help the turbo run better.
Old Oct 31, 2001 | 12:17 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: what ignition for boost? (11sec.ALL MOTOR)
Im a big believer in stock and it has been really good to me. BUT, if I were going to boost 15+psi then I would go with a MSD. But untill then Im fine with stock.
art
Old Oct 31, 2001 | 05:03 AM
BoM's Avatar
BoM
Default Re: what ignition for boost? (Arturbo)
run colder plugs though, and make sure you gap them right!
and just do a tuneup new stock wires, and rotor and cap
Old Oct 31, 2001 | 05:29 AM
ArizonaTurbo's Avatar
I woudl recommend an MSD Digital 6. The stock ignition can only handle so much. When running higher boost levels the cylinder pressure gets so high that it tends to blow the spark out, resulting in sputtering and ignition problems while under heavy boost loads. Do yourself a favor and remedy the problem before it occurs!
Old Oct 31, 2001 | 11:51 AM
SiRkid's Avatar
Default Re: what ignition for boost? (APEXSER)
I was thinking stock is fine but I have a habit of nailing the rev limiter so i want spark cut instead of fuel cut.
what about crane ignition?
Old Oct 31, 2001 | 01:15 PM
sparkz's Avatar
my plans for when ill be boostin 15-18lbs was to keep the ignition stock with the exception of an msd cap and an external coil. what do you guys think?
Old Oct 31, 2001 | 01:16 PM
b18bturbo's Avatar
What true statement when running high boost...
bobbyeg6
Feb 21, 2010 12:44 PM
turboman
Apr 14, 2006 02:37 PM
dunkd
Aug 9, 2004 05:25 AM
^jefs0ng
Oct 28, 2003 02:53 PM
SpeedMonkeyRacing
Mar 31, 2003 01:04 PM
