vtech kicking in but dont feel it
You don't feel it or it's bogging out? Which is it? Any CELs? If you don't want your thread locked you need to state all the car details.
B18C1's aren't known for having a rough transition into vtec last I remember.
Do you want the transition to be rough?
Your thread title and 1st post seem to say two totally different things. What is it really doing?
It's supposed to be engage smooth.
Check the vtec solenoid gaskets. Clean it/replace the gaskets.
Also, when is the last time the car has had a tune up? Did you check the ignition timing?
it a stock p28 no its not tunned i also tried my friends ecu and it did it worser and his is a p28 chipped and no cel's i the dizzy is at the digress it sopose to be at
You need to get the ecu chipped, and tuned.
A base map, made for your specific engine/mods will do for a little for a while, if you can't afford to have it done now.
However, you do need to have it dyno tuned.
redlseg
Aug 2, 2005 07:10 AM
schtozo
11
Feb 14, 2004 04:31 PM
