problem with d16 head after install
ok i got it all put back together it was idling okay when i accelerated it felt like it had less pwer and was super loud like when i accelerate harder mostly i drove it home and park it over night and i get up in the morning it cranks once and died now it doesnt crank at all and i looked under the hood one of the spark plugs wasnt pushed all the way down it was like --- far off could that have been my problem or do you think something alot worse?
Sounds like you didn't get the timing and other issues corrected from your other threads.
Why did you just not continue from this thread? It's all related. You keep starting new posts for the same issue as you make your problem worse.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/i-might-have-bent-my-valves-d16y7-2995688/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/2000-civic-head-problem-2991356/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/timing-belt-question-2995005/
FourthGenHatch
May 22, 2003 09:45 PM
