New 94 Si owner needs brake help!
Old Nov 5, 2011 | 02:20 PM
Claumi's Avatar
Default New 94 Si owner needs brake help!
I bought a Prelude Si that had break problems. It wont hold break fluid and there is a whistle coming from the break booster, and the abs light is on. Does the whistle mean my break booster is out or not holding pressure or something. I have no idea hows these work. Any help is appreciated!!
Old Nov 5, 2011 | 02:21 PM
Claumi's Avatar
Default Re: New 94 Si owner needs brake help!
I deffinitely spelled brake wrong :\
Old Nov 5, 2011 | 02:48 PM
Hawkze_2.3's Avatar
Yeah, it sounds like you need a new booster assuming the leak isn't coming from the hoses or connections...
Old Nov 5, 2011 | 02:52 PM
Madmaxx717's Avatar
If there are no noticeable leaks and the booster is making noise i would start with the booster and check the master. more than likely you will find that its been leaking into the booster and causing it to make noise.
Old Nov 5, 2011 | 02:55 PM
Claumi's Avatar
Thanks guys! But What about the ABS computer? I have heard of people taking it out? is it worth it?
Old Nov 5, 2011 | 05:46 PM
Hawkze_2.3's Avatar
Removing ABS properly is a lot of work....it may or may not be worth it to you. You can search for the various write-ups that are out there.
Old Nov 11, 2011 | 10:43 AM
H22a1Prelude's Avatar
ABS Light may be from something else. I had a similar issue, ABS light comes on, no ABS, about 4 months later I notice my pedal feels sloppy. Realize my brake master cylinder is bad and replace it. Pedal feel comes back but the ABS light is still present. Just thought I'd throw that out there. I didn't experience any noise, just sloppy pedal feel and the pedal dropping to the floor slowly while sitting @ a light.
Quick question for other luders (not trying to hijack), but would a CEL scanner read the ABS light as well? Have a mechanic buddy with a scanner at home and we're working on my lude tomorrow. Want to see if I can trouble shoot it and maybe help us both out. I've also been told the light could be a wheel speed sensor?
Old Nov 11, 2011 | 10:54 AM
mherkamp's Avatar
If you have an obd1 car(pre1996), the abs code will blink along with the CEL if you jump the connector under the dash. Service manual or online info will tell you what it means. GL
Mike
Old Nov 11, 2011 | 11:17 AM
Mike
So a scanner would probably read it since it flashes along with the CEL correct?
~Peace
Old Nov 12, 2011 | 05:09 AM
Hawkze_2.3's Avatar
You just need a paper clip and a book that tells you what the flashes mean...no scanner required.
Old Nov 12, 2011 | 06:30 AM
|eG|BB4's Avatar
^x2
Old Nov 12, 2011 | 06:34 AM
Apex1972's Avatar
its not that hard to remove and when you do, the abs light will stay off too. as for your noise from the booster, i would check all the hoses first before you try to replace it. and if you are considering an abs delete, you need to buy a booster,lines and master cylinder for the prelude s(not type s) or 94-97 accord dx model.
Old Nov 12, 2011 | 11:43 AM
Claumi's Avatar
I havent been on in forever. Thanks for all the input. I just ordered a brake booster and a master cylinder. Thanks everyone!
Old Nov 13, 2011 | 08:33 AM
LatnKng's Avatar
Be careful when you start to put the lines back onto the master cylinder itself, you dont want to strip the threading. Also you must BENCH BLEAD the cylinder before installation or youll have air in the lines causing the brake pedal to drop. Pre checks are always necessary. Oh and you spelled DEFINATELY incorrectly as well..its not DEFFINITELY. Quick FYI.
Old Nov 13, 2011 | 02:50 PM
Hawkze_2.3's Avatar
http://www.d-e-f-i-n-i-t-e-l-y.com/
Old Nov 14, 2011 | 03:57 PM
LatnKng's Avatar
Originally Posted by Hawkze_2.3
wow...AND I WAS WRONG!!!! You know whats messed up about that is the fact that i ACTUALLY looked it up and thats what I got!! Also txtd some ppl and got my answer as well..lol.
crxsleeper210
Aug 3, 2018 01:57 PM
Alex742
Sep 7, 2012 09:30 PM
lilo_goki
29
Feb 2, 2008 09:44 AM
Tip14
Aug 16, 2007 03:32 AM
slimbo
Apr 22, 2002 04:00 AM
