solid cel on 94 ej1 with turbo mini me, problem running
Old Nov 3, 2011 | 03:58 PM
codywashere24's Avatar
Default solid cel on 94 ej1 with turbo mini me, problem running
Ok so i got this car bout 3 weeks ago its a 1994 eg coupe has a d15b bottom end with z6 head has a TD05HR turbo off the evo 4-9 16g, gm 3 bar map, rc 550cc injectors, tuned on hondata s100.
k so as i been driving the car ive noticed it don't wanna boost good in higher gears past 2nd and sometimes would cut out, i went to wiggle my charge pipe and got oil on my finger and thought hmmm wierd took off my i/c and sure enough bout 1/8 of a quart of oil drained out, so i just let my car sit, order a turbo rebuild kit and take everything off, (only thing i took off was my turbo and manifold nothing else) well i got it all rebuilt put the turbo back on and now i have a Solid CEL car will start right up then die all it does i can keep it running if i put my foot in it and it revs to 3500 like in limp mode i take my foot off and it just dies. Any suggestions? no wires were messed with and it ran just fine before i did this.
Old Nov 3, 2011 | 04:00 PM
Default Re: solid cel on 94 ej1 with turbo mini me, problem running
i go to also check my codes and the light stays solid, ive also tried another ecu with a basemap and getting same reaction.
Old Nov 3, 2011 | 04:05 PM
grumblemarc's Avatar
The Grumpiest
Why are you running a 3bar? What kind of power & PSI you pushing?
Old Nov 3, 2011 | 04:13 PM
i got the car with the 3 bar on it already, its on 9psi and not sure gonna get it tuned when weather gets better closest place is 5 hours away, got the car with hondata s100 im taking that out and just using a phearable chip so idk what power i got right now,
Old Nov 3, 2011 | 04:14 PM
and i dont have the time to connect back to stock map and would have to order another basemap
Old Nov 3, 2011 | 04:16 PM
The Grumpiest
You don't need a 3 bar on only 9PSI. Stock MAP can handle 10-11ish so that may be your problem.
Ultimately, get it tuned.
ryguy2588
Jul 30, 2011 08:47 PM
07Lxcoupe
Feb 23, 2011 06:31 AM
romoracing
Dec 3, 2008 06:10 PM
94DCLS
Jan 23, 2008 07:20 AM
sykotic
Mar 15, 2005 03:05 PM
