H22A Turbo Hard to start on cold days?
Old Nov 3, 2011 | 10:32 AM
H22AFerio's Avatar
Default H22A Turbo Hard to start on cold days?
Hey does anyone with a boosted car have a problem with cold starts like this morning for example about 46 ish degrees?? I went to crank the car over started right away but then stumbled a few times and then shut off.. then I waited a second primed it and cranked it over again and it stated running right away?? but it sounds like it has a miss until the temp gauge warms up and then it drives perfectly fine!? its been doing this only in the morning when it is really cold? so the last few days or so any Ideas? fresh build, fresh tune, fresh plugs and wires.
Old Nov 3, 2011 | 11:27 AM
thenext's Avatar
20% cooler
Default Re: H22A Turbo Hard to start on cold days?
There is a formula with Reliability and Performance somewhere out there. As performance goes up, reliability goes down. I don't own a boosted car but this sounds like a pretty normal problem.
Old Nov 3, 2011 | 11:31 AM
H22AFerio's Avatar
haha yeah sounds about right.. Im just new to the whole turbo thing and the car has only done this a few times so I was worried is all.. but I just got off the phone with a friend of mine and he has a similar problem on cold days.. So if any one can give me any other Ideas of what it could be that would be great.
Old Nov 3, 2011 | 11:33 AM
thenext's Avatar
20% cooler
Question- Are you running an aftermarket fuel pump?
Old Nov 3, 2011 | 12:40 PM
grumblemarc's Avatar
The Grumpiest
No. Not normal.
Old Nov 3, 2011 | 02:57 PM
H22AFerio's Avatar
yes Im running a walbro 255LPH stock lines, Precision 880cc Injectors.
Old Nov 3, 2011 | 02:59 PM
The Grumpiest
This is in a Civic? Better check your logs. Might be your tune.
Old Nov 3, 2011 | 03:03 PM
H22AFerio's Avatar
hmm maybe so.. its only cold weather that affects it thats what i dont understand any other day it I crank it over and its fine but when it drops to 30-40 degrees it cranks over right away then stumbles and dies the second time I crank it fires right away and runs fine?
Ray Rowe's Avatar
my boosted z6 setup does this same thing when its cold and cranks fine when its warmer out.
Old Nov 3, 2011 | 03:10 PM
The Grumpiest
It must be when the car was originally tuned. In the cold my car runs better the colder it gets.
Old Nov 3, 2011 | 03:14 PM
H22AFerio's Avatar
ok good! I just got off the phone with my buddy and his boosted gsr does the same thing with this crappy washington weather haha
yeah my car runs great in the cold as well! its just the start up that rough after that the rest of the day its fine?
Old Nov 3, 2011 | 03:15 PM
thenext's Avatar
20% cooler
That's usually what happens when an engine isn't getting enough fuel. It's a known fact that gasoline doesn't evaporate as easily when it is cold outside. Boosted setups need fuel delivered faster than non boosted so I am wondering if it is cold fuel or an OEM fuel pump just not able to prime quick enough.
Old Nov 3, 2011 | 03:19 PM
H22AFerio's Avatar
Hmmm Im kinda wondering if my walbro fuel pump is getting tired? well according to my AEM wideband the A/F at startup is a little lean it bounces between 15-16.8 and when its warm its aroud 14.3.
Old Nov 3, 2011 | 03:23 PM
thenext's Avatar
20% cooler
It's either the pump or the tune.
Old Nov 3, 2011 | 03:24 PM
The Grumpiest
I'm going to put money on the tune. Why? Because when it's extremely hot outside I have the same problem. My car was tuned in cold weather.
Old Nov 3, 2011 | 04:08 PM
H22AFerio's Avatar
that would make sense.. it was cold as a wiches tit when I got mine tuned it was on the Octover 27th? so mayby I'll see if it continues to do it, and if so have him richen up maps that startup runs on I guess. well thanks for all the input guys its much appricated
crashtest2600
May 14, 2012 02:33 PM
skatetrainer
Dec 24, 2007 07:06 PM
Boostless97Lude
Jan 11, 2003 09:53 PM
