Where to find a headlight assembly?
Old Nov 1, 2011 | 09:13 PM
R-gonaut's Avatar
Default Where to find a headlight assembly?
So I got a 94 GSR with a leaking passenger side headlight. I've looked in the forums, but 94-97 headlights are hard to come by...
Where can I buy one, new or used? With winter coming, the water in the headlight assembly will just freeze and block out all the light coming the bulb, pretty useless!
Thanks! :thumbsup:
Old Nov 1, 2011 | 09:18 PM
hbcrazy88's Avatar
Default Re: Where to find a headlight assembly?
if they are not broken you could just clean them and re-seal them..... maybe a tsx retrofit or something baller
Old Nov 1, 2011 | 10:30 PM
UnleashedEJ1's Avatar
Google search it, You can buy new OEM from places online like Del ray Acura or OEM replica's made by companies like TYC online. I bought a set for my 98-01 front off craigslist, they were TYC but almost new. quality isnt too bad either.
Old Nov 2, 2011 | 12:29 PM
R-gonaut's Avatar
What do you use to re-seal them? Silicone?
Old Nov 2, 2011 | 12:35 PM
R-gonaut's Avatar
Anyone got a link on a cheap, DIY HID retrofit?
Old Nov 2, 2011 | 05:50 PM
fcm's Avatar
fcm
Old Fart
Local bone yard is the first place I would look, unfortunately the closet PicknPull is 7hr from you, [Tallahassee] and they only have two G3s, so sad. 94
Old Nov 2, 2011 | 08:43 PM
hbcrazy88's Avatar
yea i would just use a clear silicone.
here is a link for tsx retrofit, incase you need to know the process of taking them apart to get all the water and clean them.
https://honda-tech.com/forums/lighting-107/integra-hid-retrofit-how-2836459/
Old Nov 2, 2011 | 09:23 PM
I didnt use anything to re-seal the lights. When I heated them back up to put on the newer lense the original sealant heated up and made a nice seal. I have heard of people using the clear silicone around the headlight too. That is a good fix to a leaking light also.
Old Nov 4, 2011 | 06:25 PM
R-gonaut's Avatar
Thanks guys!
MotorMouth93
Mar 27, 2016 04:45 AM
NashvegasCg
Feb 6, 2010 11:33 PM
biggjerryc
Jul 17, 2008 04:02 AM
Radim
Apr 2, 2008 02:18 PM
hondaracin24
Oct 27, 2004 08:51 AM
