How to differentiate Axle shake from Transmission shake?
So lately my car has been shaking, and getting worse, but **only** when there is some descent load on the engine IE: accelerating
If I am coasting, or decelerating, the car is fine, but only under acceleration will the car shake. The more load = the more shake
I have pretty much narrowed it to either an axle or my automatic transmission but i want to know if there is any DIY way to really check (i have access to a lift//garage//tools)
this is on a 2002 civic with a 2003 auto transmission (it had been replaced about a year ago)
Definitely, the axle should have only one motion. Rotation. I heard some rattling and suffered from jerky shifts from my motor mounts being blown out. All civic owners should check those... Really inexpensive fix and it does wonders for manuals and automatics. Also, if you have bad motor mounts it can turn into a growing problem one goes bad... and another one... and another... then your exhaust starts leaking because the motor is moving too much.
I am having the same problem with my 03. Did you resolve your problem? I have pretty much narrowed it down to either axles or mounts. Will be looking at it this weekend.
Freemananana
44
Jul 23, 2014 02:57 AM
that1s10
Nov 16, 2008 08:06 AM
96hondab16a
14
Apr 11, 2006 05:24 AM
