LS/VTEC Motor
Old Nov 1, 2011 | 05:24 PM
peep's Avatar
Default LS/VTEC Motor
Read this before you even bother contacting me
Got a nice little Ls/Vtec setup here for sale, Was in the process of building a nice little N/A setup, but the process began to slow and I would rather have cash in my hand than a slow moving project taking up space. I personally Pulled the LS crank From The block, Still Had the OEM Honda PR4 bearings on it, all in great shape. I also personally Pulled the head off another Ls/Vtec motor, which I drove to my house, pulled in my shop Where I used my tools/knowledge to un-install the head. It ran perfectly fine. No bent valves, flat cams, etc.. SO please no smart guys trying to give me bs info on my parts. I PULLED THEM FROM RUNNING MOTORS. This motor will easily WAX any slightly modded DOHC V.
IT'S CLEAN!!
Head:
JDM B16A
Stock internals
Power Chamber Intake Manifold
AEM Fuel Rail
AEM Fuel Pressure Regulator
DSM 450cc Injectors
Sensors and VTEC silenoid included
Hardware included
NO VALVE COVER AT THE MOMENT I SOLD IT (if i get one before sale it will be included at no extra cost)
Block:
Ls Block Stock bore (has been honed)
Has everything but Windage tray (got damaged)
Comes with stock flywheel
As for the rotating assembly I have either Type R or LS crank, type r rods with damged pistons (will come with a set of LS pistons) and a set of LS rods and pistons
Other Information:
1. The Type R rods have ARP bolts
2. The Type R crank needs a polish or regrind, spun bearing in journal #1
3. The LS crank is virgin, never turned or had spun bearing
4. The Type R rods are the ones with the WHITE dots on them in the pictures
Quick Recap:
I want $1,000 for the setup which includes:
1. Full Long Block
2. Crank of choice (Ls OR Type R)
3. Rod piston setup of choice (full Ls OR Type R rods with LS pistons)
4. You dont get all of it make a choice.
Do the math guys its A lot of potential Power for the money, May trade for:
1. Flawless set of Motegi TRAK-LITES w/GOOD rubber (15,16) + couple extra bones on top depends
2. Ipad2 w/ Couple extra bones on top
3. $1,000 Cash money!
(541) 971 9379
Located in Albany,OR.... YOU PICK UP! No deliveries
Old Nov 1, 2011 | 05:48 PM
KINGVEM^^ED6's Avatar
Default Re: LS/VTEC Motor
Vtec
Old Nov 6, 2011 | 08:20 PM
lukerc45's Avatar
Looking for any trades?
peep
Northwest (Sales)
Nov 29, 2011 09:44 AM
DA STRIKER
Dec 2, 2010 02:45 AM
Austinbionic316
Jan 13, 2004 11:46 AM
90A1TEGGY
Jul 19, 2003 01:01 PM
IlL Te GeE Ie
Jun 19, 2002 11:28 PM
