Can I use a ls throttle body with a gsr intake manifold
Old Oct 31, 2011 | 11:33 AM
b20vteclsintegra's Avatar
Default Can I use a ls throttle body with a gsr intake manifold
Lilke the title says I was wondering cause people are telling me that I can then I have others that say I cant. Im doing it now but my car is in safe mode cause its has 2 codes tps and map, So can someone please till me
Thanks
Old Oct 31, 2011 | 01:01 PM
rico05's Avatar
Default Re: Can I use a ls throttle body with a gsr intake manifold
Just change out the actual sensors.
I imagine that you can after looking at pics online. Only difference could be OBD1/OBD2 and FITV. For reference, I am running an AP1 S2000 throttle body on my GS-R.
Old Oct 31, 2011 | 02:29 PM
mouab18c1's Avatar
Change out the sensors is what you need to do. You can run the LS tb but you will need a ls throttle cable. Unless you switch the tb pulleys.
Old Oct 31, 2011 | 02:41 PM
__oversea's Avatar
They are interchangeable, but you can make it fit.
Old Oct 31, 2011 | 06:46 PM
I have ls throttle cable its longer then gsr right? Now i just switched tps and now my check engine goes away but comes back on sometimes.......
Old Nov 1, 2011 | 10:28 AM
So I tryed to use a ls throttle cable and its too long. So I just put in a gsr one and it doesnt work at all its too short. Someone help me out please
Old Nov 1, 2011 | 12:48 PM
mouab18c1's Avatar
Use the ls tb and switch the GSR tb pulley onto the ls. If you do that you can use your gsr cable.
Old Nov 1, 2011 | 02:29 PM
rico05's Avatar
I had to use GSR throttle cable bracket and pulley on my S2000 TB on GSR intake mani using GSR cable. You may need to do the same for your issue.
Old Nov 1, 2011 | 02:40 PM
DirtyDA9's Avatar
So I will have to change my throttle cable in my integra to work with my gsr head?
Old Nov 1, 2011 | 03:17 PM
mouab18c1's Avatar
Depends which cable/ tb you are using. You want them to match
Old Nov 1, 2011 | 04:09 PM
DirtyDA9's Avatar
Ok, I have a gsr head/throttle body, in an integra ls, so it's an ls cable... So I will have to use my ls tb?
Old Nov 1, 2011 | 04:13 PM
mouab18c1's Avatar
I would get a gsr cable. That would be easiest since the ls cable is mounted differently on the IM than the GSR.
Old Nov 3, 2011 | 07:42 AM
Yeah you cant use a ls throttle body with gsr head. The cables dont match up. You would have to rig it to work.
Old Nov 3, 2011 | 09:29 AM
DirtyDA9's Avatar
So then GSR cable with GSR TB?
Old Nov 3, 2011 | 10:22 AM
mouab18c1's Avatar
You can use any tb you want. Read what i posted earlier in this thread. Same questions being asked over and over in one thread
Old Nov 3, 2011 | 07:52 PM
DirtyDA9's Avatar
So then I can just switch to the ls throttle body cable on the gsr tb right?
Old Nov 3, 2011 | 10:41 PM
mouab18c1's Avatar
Yeap as long as you switch the ls tb pulley onto the gsr tb.
Old Nov 4, 2011 | 02:39 PM
DirtyDA9's Avatar
Oops yea I meant to put ls pulley not cable. But thanks for the help.
ArsenMotorsport
Sep 9, 2013 12:29 AM
AccordSleeperZzZ
Mar 31, 2008 03:50 PM
Steak84SS
Jun 13, 2004 02:26 PM
filtereds0ul
Nov 12, 2003 09:30 PM
