94 del sol fuel pump only comes on when its warm
fuel pump only comes on when its warm and some times it wont come on at all i replaced the main fuel relay and i believe my ignition is working fine..any comments?
Thread titles must summarize the tech problem - edited.
-Clean and tighten the G101 ground on the thermostat housing.
-Make sure fuses 24 and 31 are not loose.
-Swap in a known good ECU.
B17SolRide
18
May 12, 2012 06:34 AM
