DUMP TUBE
When you are saying power - are you referring to horsepower or torque? It depends on how big you go... you can gain horsepower this way to a point but you will lose torque. Of course there is a point where things will balance and unbalance on either end of the spectrum.
You will gain power if you run a dumptube, don't have a wastegate dump into your engine bay. Horrible for the turbo to be sucking that back up.
The dump tube needs to be long enough for all the exhaust gases to completely escape the engine bay. If your turbo is breathing exhaust gases, you will not only loose power but you are more likely to detonate.
**** would melt quick. where ever that valve is pointed is going to get hot in a jiffy. horrible for detonation too since you'll be introducing 1000+deg air into the intake area. so actually, yes, you will loose hp with no dumptube
You're trying to liken this to a 38mm-60mm blowing straight exhaust gases out through the entire engine bay, then the turbo pulling all of that soot and heat back through the engine at WOT. Yeah, that's detonation central right there.
good god you would loose a ton of hp, iat would be out of control, possible pre ignition due to increased instability of high iat air.... the list goes on, and does include melted ****.
i had a friend who picked up 40 something hp on the dyno just from extending his dumptube to behind his oil pan. i saw the whole thing happen right in front of me being there that day
**** my dumptube exits out of my bumper to really be sure that hot, oxygen deprived gas is no where near my turbo inlet (and slightly to annoy people when the gate opens up)
EK FLY
Jul 8, 2006 06:26 AM
