Oil Filter is Stuck, I Need Help??????
Old Oct 6, 2002 | 10:47 AM
integraautox's Avatar
Default Oil Filter is Stuck, I Need Help??????
Ok I am changing my g/f's oil on her 2001 gsr and I have already drained the oil. I tried to get the filter off but it is stuck on there like no other. It doesn't have a grip on it or any thing i tried to wrap sand paper around it and twist it off but that didn't work i also got one of those wreches but i can't get enough torque to crank it off because there is no room to fit a breaker bar. Does anyone have any suggestions? Is it bad to put the oil in w/ out changing the filter? thanks
Old Oct 6, 2002 | 10:50 AM
Rory Breaker's Avatar
Default Re: Oil Filter is Stuck, I Need Help?????? (integraautox)
Its not great, but you can get away with it if you really are struggling.
If you can get the filter wrench and a ratchet on it, just slide a pipe on the ratchet and pull away. If not, you can always use the screwdriver method where you jam a screwdriver in it and turn, but that could get messy
I'd try the pipe first...it will work fine.
Old Oct 6, 2002 | 10:52 AM
piatl7il77's Avatar
Default Re: Oil Filter is Stuck, I Need Help?????? (newgsrdriver)
last resort is the screw driver get a reel long screw driver and aim just off center. hit with hmmer lightly and get ready fora mess. hahah that will definatly work
Old Oct 6, 2002 | 11:43 AM
ee-gsr's Avatar
yeah, no need for breaker bar. that's over kill. rachet should give u more than enuf leverage. good luck!
Old Oct 6, 2002 | 11:48 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Oil Filter is Stuck, I Need Help?????? (ee-gsr)
Sears sells those strap wrenches that can go around the filter. Use that or a good filter wrnech and grab the filter from the back end and turn like crazy! Also, be sure you are turning the wrench the right way. You should be turning the filter towards the driver's side of the car, lefty-loosey. Sometimes the elemental things are the cause for trouble. Good luck!
Old Oct 6, 2002 | 12:05 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Oil Filter is Stuck, I Need Help?????? (Gee3)
i got a filter cap that fits it perfectly and fits onto a ratchet screw. it hen got a big *** torque wrench and ripped that baby off.
worked perfect
Old Oct 6, 2002 | 12:57 PM
Night_Minx
Guest
Posts: n/a
You can pick up a oil filter "socket" from your honda dealer. I have-it even has a honda part #. Its slim, so you can plop it on there and put a 14mm wrench on there and take it off.
Old Oct 6, 2002 | 01:49 PM
Default Re: Oil Filter is Stuck, I Need Help?????? (Night_Minx)
alright thanks for the help i think im going to be forced to use the screw driver method
Old Oct 6, 2002 | 02:15 PM
piatl7il77's Avatar
get alot of rags though.heheh and dont lay directly below the filter..
Old Oct 6, 2002 | 02:38 PM
SmokeU's Avatar
Default Re: Oil Filter is Stuck, I Need Help?????? (piatl7il77)
Screwdriver trick ownz.
I've had to use it a couple time, it's messy but gets the job done.
1LowSol
31
Feb 22, 2009 05:55 PM
mrchevez
Aug 7, 2008 02:52 PM
nonbox
Jan 4, 2005 02:12 PM
EM1VtecSi
Aug 7, 2004 02:39 PM
Halo
Sep 26, 2002 11:53 AM
