EK ebay fog light install with no switch.
Old Oct 23, 2011 | 07:21 AM
born2sleep13's Avatar
Default EK ebay fog light install with no switch.
I got a pair of ebay fogs with my headlights and wasnt sure how to wire them up with the relay, fuse and switch. Friend said he could do it while painting my bumper. Turns out he couldn't and instead of just saying he couldnt, he tried to make it work and cut up the harness and now im left with just power and ground wires coming off with no harness to go to the switch.
Basically i want to just wire them into another power supply. I tired spicing them into the corner lights so they just come on when i turn on illumination. Problem with blowing fuse even when i put in a 30 amp.
I am even ok with just having them come on with ignition and just be always on driving lights. Let me know if you have any tips or ideas where to run the wires. Thanks
Old Oct 23, 2011 | 07:27 AM
grumblemarc's Avatar
The Grumpiest
Default Re: EK ebay fog light install with no switch.
Next to impossible to tell you how to wire these with Ebay fogs. They are not all created equal PLUS your "friend" hacked up all the wiring. You might want to post up some pictures. With no harness you might be screwed.
And to add DO NOT keep adding bigger fuses to prevent them from blowing. Now you have fuses rated to take more power than the wires do which introduces a fire hazard.
Old Oct 23, 2011 | 07:28 AM
blackstarhatch's Avatar
Be careful. I have had a few sets of ebay fogs before starting to buy legit parts in my later builds. I had one set that the harness caught fire and almost destroyed my hatch. I would take the time and order a Password JDM harness. It comes with everything you need and there are plenty of write ups on DIY install. It is so easy with a proper harness. Plug and play.
Basically if you dont know and not comfortable trying, have someone that does do it. Save the time and headache.
Old Oct 23, 2011 | 07:31 AM
The Grumpiest
Ha. He did have someone else do it. Now he's in this predicament.
That PWJDM harness sounds like the safest easiest solution at this point.
Old Oct 23, 2011 | 07:53 AM
hyperblu's Avatar
You can get oem raybrig fogs for $150 new... better safe than sorry. =P
Old Oct 23, 2011 | 08:14 AM
Someone who really knows...lmao
Old Oct 23, 2011 | 08:21 AM
The Grumpiest
I don't know anything. I said it "sounds" like it would be the best solution. Myself I would not have hacked the wires NOR would I have bought a crap set of Ebay fogs. I would have gotten some OEM or something as close to it as possible and then installed it PROPERLY.
You have another option or did you just come in here to play e-thug?
Next time red the WHOLE thread.
Old Oct 23, 2011 | 08:27 AM
Everyone has been there at one point. Trusting a friend that "knows what they are doing" or buying parts that are sub-par. I offered a solution. No e-thugging.
Personally I would make the guy pay for hacking up a harness and potential causing a hazard to your ride.
Old Oct 23, 2011 | 08:37 AM
The Grumpiest
Uh. Not me. If I know I can't do it or cannot do it properly I take it to professionals with good reputations.
OP. He has a point. Make your friend pay for the harness you're going to have to buy to fix his mess.
Truth be told, if you weren't confident in your abilities to install it, fixing it is going to also be beyond you at this point. Get the plug and play (?) solution.
Old Oct 23, 2011 | 09:42 AM
Wrona's Avatar
i never let my friends touch my car unless i know they have done this before and seen them do it
Old Oct 23, 2011 | 10:38 AM
Its a 99 hatch and this was a while ago he hacked up the harness. i found it today cleaning the shop but its been clipped and sodler in wierd places looks toast. It had the OEM plug on it but that is now gone too.
I wasnt comfortable doing wiring then, but since i have done partial tuck and some other leds and stuff so now i know what im doing.
So wiring it to a constant source is a bad idea?
And i put the correct fuses back in
Old Oct 23, 2011 | 10:54 AM
The Grumpiest
$50
http://passwordjdm.com/PasswordJDM-F...P2316C164.aspx
with an extra ten you can get a plug-n-play switch.
Old Oct 23, 2011 | 11:59 AM
yeah i was lookin at that. Probly what im guna go with. Thanks
Old Oct 26, 2011 | 03:07 AM
benrada's Avatar
great write up
Old Oct 26, 2011 | 03:09 AM
The Grumpiest
Originally Posted by benrada
great write up
There is no write up. Stop bumping to get your post count up.
Old Oct 26, 2011 | 06:40 AM
chasingadrenali's Avatar
the only real way that any of us can help you with your wiring, is if you post pics of the hack job that your friend did on your harness. im an electrical engineering student and have plenty of experience wiring things in to my car. i have a set of depo ebay fogs with oem fog switch. if you do not decide to buy the passwordjdm harness, post some pics of the harness and lets see if i can help.
bryanjenks
Lighting
Nov 25, 2010 07:51 PM
phrenzykEG6
15
Jul 6, 2010 06:40 AM
senorkree
20
Apr 5, 2010 11:01 PM
STUSSYxDUNKS
Aug 29, 2009 09:20 AM
Thizzed Out
11
Dec 19, 2008 11:24 PM
