alarm installed- more security needed
viper alarm is there, back up battery,multiple sirens, tucked install.. how do i properly wire a legit kill switch or switches?? no rigged up garbage, proper wire gauge to use, etc.. any help appreciated
2-4 kill switches.
Kill the fuel pump, ECU/main relay, injectors.
Some people have even been known to wire in switches to kill their headlight/tail lights.
Take the ecu out.
Break club. Not too affective for the more experienced theif, but it may stop the younger less experienced theif from trying to get the car.
Also, removeable steering wheel w/lock.
Remove fuese.
Lots of ways.
Take the ecu out.
Remove fuese.
Lots of ways.
i pull off the steering wheel every time i leave the car, every extra possible add on to the alarm is there i need to know how to wire these kill switches, please..pics, diagrams would help alot..
a kid in my auto colision class hooked up a kill switch to his stereo. idk y, but he does take it out every where he goes. when its on it complets the circuit. without it u cant start it or anything. just a idea. prolly ben thought of tho
I have even heard of people hooking the kill switches up to the AC button.
Put two switches on the fuel pump power wire. One in semi-obvious place, another in a hidden place. 2 levels of security..
Pull out the ECU fuse or put a hidden switch on it's circuit.
Hidden switch on the injector circuit.
Removable steering wheel.
These are the basic ones that seem to work the best.
As for wiring diagrams, they are available if searched for.
But no one can stop a thief from backing up to your car with a tow truck, winching it up onto the flatbed, and driving away.
best of luck.
best of luck.
lock steering wheel, remove detachable steering wheel, add steering wheel lock, clutch lock, kill switches to fuel pump,starter, and etc., stealth install, a dog, idk you can go on and on with this...
the cons of driving a nice(or any) honda..
89efDUSTY
Apr 30, 2008 06:24 PM
