ls build up.need help)
Old Oct 6, 2002 | 05:44 AM
civicguy's Avatar
Default ls build up.need help)
i just got my ls botton end done with je pistons,eagle rods,type r oil pump etc.but im worry that i tried to turn over the crankshaft with a rachet to see how the pistons were going up and down and is really hard to turn, once you turn it over then keep going a bit easier until you stop.then is a pain in the butt going all over again.ps:NO HEAD ON THE BLOCK YET,NOTHING THAT SEEMS TO STOP ME TURN IT OVER EASY
Old Oct 6, 2002 | 06:04 AM
performula's Avatar
Default Re: ls build up.need help) (civicguy)
If anything I would think that if it did turn, it would barely turn. You want it to be tight, that's new for you.
Lube the cylinder walls up then.
Old Oct 6, 2002 | 06:06 AM
performula's Avatar
Default Re: ls build up.need help) (performula)
I thought of this again, you must have a hell of a rachet. Sounds OK to me, I could be wrong.
But like I said you're lucky to move it.
Old Oct 6, 2002 | 01:30 PM
vhd's Avatar
vhd
your assembled short-block should not be hard to turn over, something is wrong. how are your bearing clearences on the rods and mains. make sure you didn't install the rod caps on backwards or on the wrong rod. tight does not mean new and lubing the cyl. wall doesn't really make a difference on how the engine will turn over . double check your assembly
Old Oct 6, 2002 | 01:55 PM
LsTurbo91's Avatar
there's definetely something wrong. That should be easy as pie to turn without the head on
Old Oct 6, 2002 | 03:13 PM
baonest1's Avatar
Default Re: ls build up.need help) (LsTurbo91)
are u like poppin veins when u try to turn it, or is it like a small struggle?? cuz my short block is tougher to turn then when i get it to turn its easier (well this is troo with eveything). but oh well
Old Oct 6, 2002 | 03:43 PM
civicguy's Avatar
Default Re: ls build up.need help) (baonest)
when i try to turn it is hard, once it start moving its easy to keep going,then when i stop and try again is the same thin all over again.
rods caps were torque to 33pnd tq,there's no noice of any kind,cylinder walls looks in perfect shape,
Old Oct 6, 2002 | 10:35 PM
b19coupe's Avatar
How are your bearing clearances ? The motor should turn freely, even after you stop and start turning again. Plastiguage the main bearing clearances. I don't recommend putting the motor together until you find out why it is binding. If you put on a block girdle, that could be your problem. Block girdles tend to **** the main bearing caps ever so slightly, but enough to cause a problem.
[Modified by b19coupe, 7:37 AM 10/7/2002]
98integralsB18
Mar 30, 2010 05:21 AM
fireblaze2k1
Jul 16, 2009 06:29 PM
slayersluck
Dec 6, 2004 11:01 AM
yusoslo
Dec 8, 2003 05:09 PM
ls_vtec_b18a1
Oct 21, 2002 07:35 AM
