not being able to rev pass 3500
Old Oct 16, 2011 | 12:59 PM
ed6chuck's Avatar
Post not being able to rev pass 3500
ok i got a ed6 91 ls turbo charged my problem is when the car was ready to be truned on i had a ls ecu and if i tryed to keep it at a steady idle lets say (1500rpm 2700rpm 3500rpms) it would idle as if i had a 2step not allowing me to rev freely. Ok so now i ran a po5 just to see if it was my ecu and the po5 doesnt rev pass 3500????? HELP
Old Oct 16, 2011 | 01:17 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: not being able to rev pass 3500
Are you building boost at that point? What did you do for your MAP sensor?
Old Oct 16, 2011 | 01:54 PM
accordin 2 me's Avatar
i dont understand gibberish
Old Oct 16, 2011 | 02:31 PM
ed6chuck's Avatar
no not yet and im running the stock one on check vlaves
Old Oct 16, 2011 | 04:14 PM
DO IT ON ALL FOURS
How did you install the check valves? In a "T" fashion, or inline? Almost sounds like you either have the TPS and MAP wiring switched or you installed the check valves wrong... Also - your wording/description is rather horrid.
Old Oct 16, 2011 | 08:54 PM
ed6chuck's Avatar
Lol I guess you have to write as if you were writing an essay for a college final or maybe people are just slow. But anyways yes I know how to install check valves.
Old Oct 16, 2011 | 10:07 PM
ic's Avatar
ic
LSTEG98
Apr 3, 2008 12:14 PM
bennyhonda7
May 11, 2005 11:38 AM
B18B EK
Mar 22, 2003 04:13 PM
Pengo
Jul 30, 2002 08:43 PM
Teluan
Sep 3, 2001 07:29 PM
