96 d16y8 turbo setup suggestions please?
Old Oct 15, 2011 | 09:11 PM
zrs6v4's Avatar
Default 96 d16y8 turbo setup suggestions please?
I have a 1996 honda civic turbo d16y8
Here are specs, im hoping to get input on what i should do next or change, what power im capable of making and so forth. A friend set me up so im sort of learning here still. Thx
Stage 2 turbo grind crower cam: Duration: 312deg. intake: 318deg. exhaust with I/E.430/.427 lift
Supertech valve springs (single spring) with titanium retainers
machined block bored .020" or 2.972" bore diameter with main girdle alignbored to specs. overall, engine has roughly 2,248miles on it
decked cylinder head and balanced crank
wiseco forged aluminum pistons 8.5:1 compression
Eagle H-beam rods with acl race rod and main bearings
Garrett 60-1 journal bearing turbo
SX performance fuel pressure regulator with Walbro 255lph pump, and RC 550cc injectors (pumping 1 lpm with setup)
apexi v-afc tuner with a safe tune setup on vehicle running 12-14psi boost right now
Tial 38mm wastegate with 18lbs. springs
Old Oct 20, 2011 | 04:21 AM
GSRswapandslow v2's Avatar
Default Re: 96 d16y8 turbo setup suggestions please?
if you have an 18psi spring...you can't run 12-14psi......
Jeff<3'sHonda
Jul 15, 2014 08:44 PM
97couped16
May 11, 2014 04:00 PM
mrguilty101
Apr 3, 2014 08:08 AM
jdmchinoCDN
Dec 14, 2010 11:28 PM
97ek4
Sep 26, 2009 06:07 PM
