Valve Adjustment?
Old Oct 15, 2011 | 04:59 PM
UniqueX707's Avatar
Default Valve Adjustment?
I been starting to hear a noise from my motor. Is it i might need a Valve Adjustment? and I been waste alot more gas then i usually do more. Pretty much it its eats it up in half the time i normaly do and i still do the same amount of driving. What do you guys think it can me let me know for what you think it is.
Old Oct 15, 2011 | 05:39 PM
mike:'s Avatar
Default Re: Valve Adjustment?
Does the check engine light come on- the yellow light on the cluster. could just be a bad sensor for the poor mpg.
Light tapping noise: valve lash adjustment https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/valve-adjustment-1998-honda-civic-ex-2895877/
If the sound is loud: A heavy metal on metal, rod knock https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/rod-knock-bearing-2471182/
If you have a manual transmission push the clutch fork towards the slave cylinder, if the noise goes away its your throw-out bearing or clutch fork
Do a tune-up: oil change, radiator flush, tranny flush, spark plugs/wires
Old Oct 15, 2011 | 05:52 PM
motegicivic's Avatar
Valve adjustment will not really help with fuel economy. Turn on the car and open the hood and listen do you hear a ticking/tapping noise, then might want to adjust valves.
How many miles on the car?
Old Oct 15, 2011 | 06:06 PM
92dxbeast's Avatar
Try cleaning your fuel injectors and checking your valve clearance won't hurt just make sure your motor is stone cold and check your oil if you treat your car good it will treat you good back
Old Oct 15, 2011 | 07:22 PM
98civdx's Avatar
Master Detailer
Tune up. OEM cap/rotor/wires, regular old parts store NGK plugs. Check/set ignition timing.
Fuel filter. When doing the ignition timing, insure the mechanicle timing is correct before doing so.
A valve adjustment, if it's needed, can help the car run/idle smoother, and quite it down a bit. But, keep in mind these cars usally do click/tick. Mine is loud as hell and valves have adjusted/check 3-4 times. It's just the way they are.
Also consider running some sort of fuel system cleaner/injector cleaner in it.
Old Oct 15, 2011 | 11:55 PM
I had my valves done as well, been awhile and still ticks/clicks nothing bad just can hear it when working under the hood.
Old Oct 16, 2011 | 07:02 AM
94eg!'s Avatar
#1 Super Guy
Loved
Worn valve tappets won't cause crazy bad mpgs. Valve clearance only loosenes over time (from wear I guess) so this actually allows less air into the engine. In fact, adjusting your valves could cause worse mpgs because they allow the valves to fully open which can make more power. This makes more likely to run at WOT...
Old Oct 16, 2011 | 09:06 AM
UniqueX707's Avatar
Thanks for the replies guy! They got me think to do some of those things.. My friend say it can be my fuel pump or a spark plug that might not be giving enough spark?. Can that be it also for the low MPG?
motegicivic: it has 159k
Old Oct 16, 2011 | 09:36 AM
98civdx's Avatar
Master Detailer
This really is just the nature of the car. lol
OP, do you have any maitence records?
Old Oct 16, 2011 | 10:03 AM
Hidenplanvew's Avatar
fuel injectors do make a clicking sound that can be alittle loud but is normal... get your ear by it and listen
Old Oct 16, 2011 | 07:34 PM
UniqueX707's Avatar
Im start to thinkmy low MPG is cause of my fuel pump and the noise might be something else
Old Oct 16, 2011 | 07:38 PM
98civdx's Avatar
Master Detailer
Fuel pump causing low MPG? How is that possible?
Old Oct 16, 2011 | 07:53 PM
UniqueX707's Avatar
LOL I dont know. What do you think it is?
Old Oct 16, 2011 | 08:07 PM
98civdx's Avatar
Master Detailer
Could be a number of things
Driving habit being the biggest one.
Old Oct 16, 2011 | 09:02 PM
UniqueX707's Avatar
I barly drove today a total of 5miles or 10miles and i went from a bit over a 1/4 to E
Old Oct 16, 2011 | 09:19 PM
98civdx's Avatar
Master Detailer
God damn. Were you rev'ing the **** out of it!?!.
Your having major issues if this really happend. And it's not the fuel pump.
Also, remeber these cars don't have baffles in the tank. So the fuel level guage will move up and down all the time.
Old Oct 16, 2011 | 09:42 PM
UniqueX707's Avatar
No not even i shift before 3K..
Yeah I know that but when it was at my house it was above a 1/4 of a tank and i turn it on and move like 500feet and bamm **** starts dropping
Old Oct 18, 2011 | 05:04 PM
mike:'s Avatar
poor mpg is probably a faulty sensor: iacv, map
but could also be a clogged fuel filter, running rich, timing is off, bad gas, leaking fuel injectors, actual leak in fuel hose, lack of maintenance, poor sparkplugs
Old Oct 18, 2011 | 07:50 PM
strategy400's Avatar
New cap rotor and wires will do wonders.
Old Oct 18, 2011 | 08:02 PM
B20BP8R's Avatar
loosing that much gas milage try looking for a fuel leak.
Old Oct 22, 2011 | 09:32 AM
UniqueX707's Avatar
I just put a bottle of STP Fuel Cleaner and im back to how it was thansk for the responds guys!
ki0326
Engine Management and Tuning
May 29, 2012 10:43 PM
MeathooK
Dec 6, 2008 12:41 PM
ea_hatch
Feb 2, 2004 06:59 PM
HBCthugg
Jan 30, 2002 01:09 PM
