Tranny help! Plz
Old Oct 15, 2011 | 04:16 PM
arzelee's Avatar
Default Tranny help! Plz
My car wont go into gear and underneAth some metAl piece came out! I m stuck and i want to see if i can fix it before i call aaa:/ i have jack and jackstand
I m in fullerton if someone want to come by and help
Old Oct 15, 2011 | 08:51 PM
mark@silbernage's Avatar
Default Re: Tranny help! Plz
doesn't sound good, but we'd need to know where the metal came from.. if it was from the shifter assembly it may be you can jury rig it (pop into 2nd manually) and limp home where it's easier to work on.
If it's thrown gears through the side - not much you can do where you are.
If some debris few up.. depends. Hate to run it w/o tranny fluid.
Good luck
Old Oct 15, 2011 | 09:35 PM
arzelee's Avatar
yeah i found out the problem it was the shift linkage that connect to the tranny and shifter. I was able to put it back together with a cotterpin where the bolt was missing but at the same time shifting is very loose. All the gears feel like neutral moving left and right what do I do when that happen? should i still drive the car?
Old Oct 16, 2011 | 10:08 PM
DAman9's Avatar
for one sounds like you need to fix that linkage
and does your car actually go into gear when you say it feels like its in neutral ?
Old Oct 17, 2011 | 12:57 PM
mouab18c1's Avatar
Sounds like your bushings are shot
Old Oct 17, 2011 | 01:29 PM
JDMguy88's Avatar
just replace that cotter pin with a bolt and it wont move around so much, not sure how that bolt could have come out in the first place tho
Old Oct 17, 2011 | 04:24 PM
fcm's Avatar
fcm
Old Fart
What part/bolt fell out... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal..
What is the MM&Y of your car?
The above link is a 94 Integra LS 5 speed manual. 94
Old Oct 17, 2011 | 05:19 PM
JDMguy88's Avatar
it sounds like either the bolt at the base of the shifter or the bitch pin, im not sure how the bitch pin would just fall out so my best guess would be the bolt where the shifter attaches to the linkage. I guess only the op would know for sure tho
stupid fast
Nov 22, 2012 04:21 PM
bowdown201
Jan 8, 2009 10:19 AM
goldenhatch13
Jul 2, 2008 08:53 AM
DriveSlowHomie
Apr 16, 2008 03:25 PM
b18b1hatch1
10
Jan 14, 2006 11:39 AM
