need a good shop to take my sis car.
Old Oct 14, 2011 | 03:21 PM
HFpower's Avatar
Default need a good shop to take my sis car.
Cant figure why my sis car is still overheating. time to take it to a shop or somebody.
anything near riverside area?
Old Oct 14, 2011 | 03:32 PM
96DelSol's Avatar
Default Re: need a good shop to take my sis car.
What kind of car is it?
Old Oct 14, 2011 | 03:34 PM
jdm_bones's Avatar
Maybe blow headgasket or a cylinder wall in the block is cracked, maybe air pocket in the cooling system, or bad waterpump....
Old Oct 14, 2011 | 03:43 PM
HFpower's Avatar
94 civic ex
auto
195xx
Old Oct 14, 2011 | 03:44 PM
HFpower's Avatar
not a blown head gasket the car doesn't smoke at all
Old Oct 14, 2011 | 03:47 PM
96DelSol's Avatar
Symptoms?
Old Oct 14, 2011 | 03:48 PM
jdm_bones's Avatar
Do a leak down test... Also disconnect your fan and let run untill all the boiling bubbles stop, and the water start to want to come out the top, close the radiator with cap, plug your fan back up, and top off the res. check that your radiator cap works, this can also cause overheat!There is a seal on there make sure it is still intact, and not torn. GL
Old Oct 14, 2011 | 03:54 PM
jdm_bones's Avatar
Also remove your oil cap and make sure that the oil doesn't look like milk chocolate, that would a big indicator that your HG is blown...Leak down might tell you from where, if it is...once again GL.
Old Oct 14, 2011 | 04:10 PM
reznunt's Avatar
Old Oct 14, 2011 | 04:11 PM
HFpower's Avatar
ok thanx
Old Oct 14, 2011 | 04:14 PM
jdm_bones's Avatar
NP
Old Oct 14, 2011 | 05:26 PM
sii.'s Avatar
Take it to the lab junkies
Old Oct 14, 2011 | 05:35 PM
civic nation's Avatar
dick
Old Oct 14, 2011 | 05:58 PM
gorillafart's Avatar
so exactly what are you selling?
Old Oct 14, 2011 | 06:31 PM
cup cake's Avatar
my homie owns circuit form off the 215 in sb
Old Oct 14, 2011 | 07:16 PM
DO/\/\O's Avatar
he needs to find a shop to fix his sis car.
Old Oct 14, 2011 | 08:20 PM
R6fourK's Avatar
My father has a shop in Riverside, located off Pierce and the 91, called Top Auto. He's been a mechanic for 20+ years. Check him out. His shop number is 951.351.2059.
Old Oct 14, 2011 | 08:24 PM
DC2.KILLA's Avatar
No Sales Forums
From: where your homies are fake as four dollar bills
hit me up ill fix it up 909-509-9564
Old Oct 14, 2011 | 11:30 PM
gsle3per03's Avatar
Dam im on the same boat. Replaced almost every part of the cooling system already. It might be a bad temp gauge cluster? Test out the cluster and see if its the indicator is on "C" on cold startup. Mine automatically jumps to 1/3 mark on cold start. Still trying to track down another cluster to test. Best of luck
Old Oct 15, 2011 | 01:52 AM
dopeyesw310's Avatar
It might just b a bad headgasket ive done alot of cars that dont smoke or the oil getting milky.
It might just b leaking compression into the water ports. Do your hoses get all balloned up
Old Oct 15, 2011 | 02:47 AM
IT'S ME DAVID's Avatar
NooB
Warped head block
Old Oct 15, 2011 | 07:04 PM
sii.'s Avatar
Maybe haspecialists can help?
Old Oct 15, 2011 | 07:09 PM
tonylovesjdmEF9's Avatar
bring it to me ill do it for 200 bucks plus whatever parts or you supply the parts im off the 60 and country villeage ave ase certifed mechanic and smogtech licensed too.... and its the head gasket i had a eg with a crack head gasket it would be running cool all day till after say a long drive or 5 hrs of straigth drivign it would just over heat and there wouldnt be no smoke or milky oil its a small crack on the headgasket
Old Oct 15, 2011 | 07:10 PM
would you take your dx there????
Old Oct 15, 2011 | 07:12 PM
darkDB1's Avatar
Take it to haspecialist lol
xSOHC
Aug 10, 2013 01:52 PM
team 15
May 9, 2007 01:09 PM
EK VTi
Sep 5, 2006 01:04 PM
dabrown
May 23, 2004 01:58 PM
flat-blk-HB
Oct 3, 2002 10:07 AM
