bad trans or bad linkage?
Old Oct 11, 2011 | 06:10 PM
monster d's Avatar
Default bad trans or bad linkage?
Alright..I just swapped a b18a1 into my 89 civic si. Was a pretty fun job. We get it into the car and start to drain the eng and trans fluids and replace it and start it up...well first thing the trans fluid was ****ing silver..next I put a magnet in the oil pan and there was metal shreads all up in that crap..so when we finally get it running right and test drive it 1/3/5 are really hard to go into and out..sometimes(Now this is where I think it could be the linkage or something) and sometimes it shifts like it has no damn problems and will go in and out of 1/3/5 like cake. So I'm trying to see if I can save me some money from getting a new cable trans.
Thanks for the help.
Old Oct 11, 2011 | 06:45 PM
90ZCREX's Avatar
Default Re: bad trans or bad linkage?
I suppose the linkage bushing could be going out, along with possibly the motor mounts. But most likely something in the trans as the silver fluid is never a good sign. As for the motor I would run a leakdown or at least a compression test to make sure the motor is not fubar. It would suck pretty bad to get beat by a stock crx because your motor has such low compression (happened to me).
Old Oct 11, 2011 | 06:59 PM
monster d's Avatar
Mounts are solid. Where is the linkage bushing at? I am planing on checking compression soon. Since dude already burned me on a trans..****ing $700 for the full swap lol
Old Oct 12, 2011 | 03:33 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Ok - you never said what linkage you were using in the first place. Typically metal shavings in the oil pan leans more towards rod/main bearings. So use an oil gauge to check your pressure. It's always a good idea to leak-down and compression test an engine. I try to do it at least once a year to all my vehicles to monitor their condition.
Old Oct 12, 2011 | 05:19 AM
monster d's Avatar
The Integra linkage. Why would it be the rods and main bearings if the fluid came out of the trans?
Old Oct 12, 2011 | 05:56 AM
McGruber's Avatar
Because you said you put a magnet in the oil pan and had tons of metal shards. That would most likely be bearings. The intermitent problem of the tranny not going into gear sometimes could also be a bad clutch disk. When the springs go bad in the disk sometimes they will not allow you to engage at all but then the next minute they will be fine. I've seen some with that same problem and once you pull the tranny the disk springs fall out lol. It's probably your tranny though, especially if your fluid is all silver and sparkly.
Old Oct 12, 2011 | 06:21 AM
DO IT ON ALL FOURS
Key word = Oil Pan... just so you know - manual transmissions do not have pans. Amazing!
So did you modify the linkage in any way?
Old Oct 12, 2011 | 06:47 AM
monster d's Avatar
Oil pan. The thing you drain the oil in bro lol.
Well when we first tried dropping it with the lift the linkage that bots to the stick was hitting the ground and I was thinking maybe kinda bent it. But idk I'm just trying to cancel stuff out.
I'll probably just get another trans and replace the clutch and resurface the flywheel while I'm down there.
Old Oct 12, 2011 | 08:58 AM
DO IT ON ALL FOURS
Stay in school and keep learning the English language... Also, what you call the "oil pan" should probably be referred to as a drain pan, oil catch pan, ect...
You say you drained the engine and transmission fluid. After you begin stating the transmission fluid was silver, you then go on to talk about putting a magnet in the oil pan. So this would clearly indicate you were talking about the engine now.
Regardless, if your linkage isn't bent or defective in any way, I would suspect the transmission. If you install a known good transmission and still have a problem, I would assume your linkage to be the problem. Also, I am not your "bro" but you can call me "Pappy" or "Pops"... child.
Old Oct 12, 2011 | 09:43 AM
4drEF's Avatar
Keyboard Humorist
the trans has a magnet in it to catch debris from normal wear and tear.
If you are getting metal in the drained oil then you need to drop that tranny to repair or replace.
It is only a matter of time before it craps out on you.
Old Oct 12, 2011 | 10:32 AM
monster d's Avatar
Alright old man, I already know the English language. You don't have to be a douche because your an old hag and think you know what the hell your talking about.
I didn't know they had that. Yeah when the fluid came out it was like pure silver and the shreads where pretty big. I already sourced out to. Hopefully I can find a good deal on onr
Old Oct 12, 2011 | 11:59 AM
alvfrancisco's Avatar
my car its doing the same thing. this is the second tranny doing it, also this tranny was good because i pull it out my running car... Any help???
Old Oct 12, 2011 | 12:38 PM
all-motor-crx's Avatar
first off dude, dont be a dick to someone who probably knows alot more then you and is trying to help you out and fix your problems, he was first only asking if you were meaning the oil pan on the engine, because that's what you stated.
if you have metal shards in your oil from the engine, then yeah it could be rods, bearings.
in the trans, if theres shards i'd say replace/rebuild your transmission. but, you could go the cheap way first, try changing out the shift linkage, check the clutch and replace it if need be. then if it's stil doing it buy a tranny, it wont hurt you at all cuz even if you just bought a trans you'd still have to buy the linkage and a new clutch.
Old Oct 12, 2011 | 12:39 PM
thread jackinnn.....
but check your clutch
Old Oct 12, 2011 | 12:43 PM
4drEF's Avatar
Keyboard Humorist
Yup!
#5 in this pic
Old Oct 12, 2011 | 02:09 PM
monster d's Avatar
Dude was a dick first lol.
Yup!
#5 in this pic
well I bet that magment is loaded with shreads of metal
Old Oct 12, 2011 | 09:21 PM
91ef18's Avatar
anyone have a diagram on how to take the y1 b16a trans apart. i need to replace the syros.
Old Oct 13, 2011 | 02:52 AM
DO IT ON ALL FOURS
Make your own thread - stop threadjacking... stop being cheap and buy a repair manual... be resourceful and SEARCH... it's not just a walk in the park and it sounds like you need to get educated... heck there are even How-To videos on this...
Old Oct 13, 2011 | 05:43 AM
TearSDMF89dx's Avatar
im gonna have to agree with pappy on this one.......lol
Old Oct 13, 2011 | 10:45 AM
monster d's Avatar
Got a trans for 100. Waiting for my paycheck to get a new clutch and my flywheel resurfaced
Old Oct 13, 2011 | 10:52 AM
4drEF's Avatar
Keyboard Humorist
Nice price on the trans!
While it's out, you might want to invest <$50 to get a new input shaft bearing and seal.
Old Oct 13, 2011 | 10:57 AM
monster d's Avatar
Okay I should have enough for it. Clutch cost 100 and resurface for 20
Norb427
Honda Civic (2001 - 2005)
Nov 16, 2016 05:28 AM
Probot
Jan 4, 2008 04:22 AM
NMef9
Dec 26, 2006 07:00 AM
xteg95
Nov 22, 2003 08:10 PM
