Idle problems with my DC5 type R
Hi, I have a JDM DC5 type r and it's starting to having problems with idle after driving normally. It's goes from 1000rpm to 2000rpm and keeps doing that till I beat the hell of it, then it stops, but keeps coming back more and more. I know it has something to do with the IACV. What should I do to fix this problem?
I've done all of that and it's worse than before. It does it only when the car is moving and when I have the clutch in. I have sprayed WD40 in it (to lubricate)and I removed the coolant hoses from the throttle body. I also cleaned the throttle body completey. Should that be something wrong?
Sprayed carb cleaner all over and around it. No leaks.
I think I have to take it off again and reclean it. The only thing I don't understand is that it's doing it only when the car is moving and not when parked.
EnviedByMany
Oct 21, 2010 07:23 AM
