Honda S2000 Honda S2000
Idle...
Old Jul 7, 2005 | 09:37 AM
OriginalFive's Avatar
Default Idle...
When the car is at idle, its suppose to be at 1000rpm, am i right? my car idle's at 1000rpm, then drops to 900, then to 8-700 rpm, then goes back up to 900. i was just wondering if this is a problem? i havent gotten around to cleaning/spraying my throttle body with carb cleaner...is it the same thing, or is it totally different? could it be the heat and that the ecu is trying to adapt to the conditions?
im just concerned, thats all. thanks guys!
Old Jul 7, 2005 | 09:44 AM
terd ferguson's Avatar
Default Re: Idle... (OriginalFive)
RPM's dipping momentarily like you describe is normal in my experiences. It should only happen occasionaly at stops.
Old Jul 7, 2005 | 09:51 AM
hypnosisracing's Avatar
Default Re: Idle... (terd ferguson)
Should not be a consistant thing...but has happened to us occasionally, especially with the a/c on...it will dip down to 800, then pop back up and regulate...
Old Jul 7, 2005 | 09:54 AM
WowOzYouRock's Avatar
the worst thing you could do is clean ur throttle body wit carborator cleaner .. you gonna ruin all the sensor ... its ok for carborator cars cuz it aint got none ( sounds like a rap lyrics ) ... anyway, its normal , mine does that too ...
Old Jul 7, 2005 | 09:56 AM
Mr. Lucky's Avatar
Default Re: Idle... (hypnosisracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing &raquo;</TD></TR><TR><TD CLASS="quote">Should not be a consistant thing...but has happened to us occasionally, especially with the a/c on...it will dip down to 800, then pop back up and regulate...</TD></TR></TABLE>
not to thread jack. but can you guy turn off your a/c when the defrost mode is selected? i know i can't
Old Jul 7, 2005 | 10:56 AM
papa5murf's Avatar
Default Re: Idle... (bs-inc.s2k)
it sounds fine to me....... on the guage it shows 1000 but it's really 800-900....
Old Jul 7, 2005 | 12:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bs-inc.s2k &raquo;</TD></TR><TR><TD CLASS="quote">
not to thread jack. but can you guy turn off your a/c when the defrost mode is selected? i know i can't </TD></TR></TABLE>
I have an 01 and I'm able to turn off my a/c when using deforst.
Old Jul 7, 2005 | 05:17 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Check your manual about the defrost thing, I'm pretty sure it says how to change that. On my RSX-S you could turn it off.
Old Jul 7, 2005 | 05:34 PM
Nishant's Avatar
there is a fix for this, search s2ki. if you can't find it, let me know
Old Jul 7, 2005 | 06:48 PM
Default Re: Idle... (Nishant)
thanks guys for the info. i really appreciate it. thought i'd just ask and make sure.
Old Jul 9, 2005 | 05:06 PM
H0ND@H3@R7's Avatar
Dont worry its normal
Old Jul 11, 2005 | 01:46 AM
Will_ChinLee's Avatar
i had a quick question. when you start up on a warm start do your RPMs drop down to like 5-600 just for a second and them pick back up? someone was saying i need to have my valves adj. just wondering if anyone else gets this.
riS.I.R
10
Jan 18, 2010 12:02 PM
twentyhurtz
Dec 5, 2008 07:30 PM
V-Thang
Acura TL, RL & ZDX
Feb 24, 2004 02:10 PM
Vp Special K
Apr 4, 2003 09:14 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
