A couple of questions about my Turbo setup
Ok so I bought my brothers 99 Acura Integra Ls turbo. My concern is that it is running an fmu right now and I want to delete that asap. So how should I go about it. Which software is the best to tune and im currently running 8lbs on what I beleive is stock injectors on a Garrett 50 trim. I want to turbo boost to 12lbs on a safe tune and are 400-600cc injectors be to big or not enough. A little input would be nice.
Thanks
Also whats your input on XS power intake manifolds? As it already has on it.
Thanks
I'd go with 650s+, you will run out of room on 450s really quick with that setup.
Hondata, Neptune, ECtune. All similar in pricing and how they work. Find a tuner local to you and see what they're most comfortable in working with and go with that. I believe Neptune and ECtune have the ability to do a cheaper version that doesn't have datalogging and what not so that may be a viable option for you as well.
Never heard of that intake manifold, but if it doesn't leak I wouldn't really worry too much about it. If it bothers you too much just find a stocker.
