S40-e5f to S20 transmission swap - question about transmission codes
Old Oct 9, 2011 | 07:18 PM
97accordbuildlx's Avatar
Default S40-e5f to S20 transmission swap - question about transmission codes
i got a tranny from a dude that claimed it was an si tranny. it said s20 on the code. i didnt know any of the codes for d series trannys so i t hought ok its an si. so im in the middle of swapping out my e5f transmission for the new s20 transmission. noticed where the numbers on the s20 trans say "A000" instead of "b000", which many fo you know that B is the si/ex and A is for the dx, right? correct me if im wrong. my E5f also has "A000" stamped on it as well. my question, how much of a difference will i see between the e5f and the s20 B, and how much of a difference between the s20A and s20B....
Old Oct 10, 2011 | 12:30 AM
virgineg6's Avatar
Default Re: e5f a000 transmission question.
Google is your friend.
Old Oct 10, 2011 | 01:18 AM
HondaPartsHero's Avatar
Technical Hero
http://www.hondacivicforum.com/forum...ion-faq-57398/
Old Oct 10, 2011 | 01:22 AM
NOFX's Avatar
H-T White Ops
Saying "search" won't help anyone later who finds this thread when they search, plus it's against site rules to say that and not actually help.
As I understand it, the S20 is the D-series '92-'95 manual transmission (at least in the US) and the S40 is the D-series '96-'00 manual transmission (at least in the US).
I wasn't sure of the answer beyond that, but I found this:
http://www.knology.net/~jediklc/gearratiosdseries.htm
To ID : Look by the fill plug. You'll see a circle cast into the housing.
P20-A000 = DX,CX,VX trannys
P20-B000 = Si,EX trannys.
Here's the manual transmission codes for '92-'00 Civics I know:
S40-K4F = EX (D16Y8) (I confirmed this on a '98)
S40-E7F = CX (D16Y7) (I confirmed this on a '97)
S40-E5F = ?
S4C-??? = Si (B16A2)
I have no idea what an S40-E5F comes out of so it's difficult for me to answer your question.
Old Oct 10, 2011 | 04:45 AM
94EG8's Avatar
Seagull Management
D16Y7 equipped coupe/sedan most likely. Hatches had the same gearing, but with a longer final drive for '96 - '00. Also HX trannys are also stamped B000, but they're geared long, they just use a big bearing case for whatever reason.
Old Oct 10, 2011 | 05:35 AM
NOFX's Avatar
H-T White Ops
I wish I had more confirmation for these identification numbers. I'd check more cars at salvage yards, but more seem to be automatics!
Old Mar 18, 2012 | 03:59 AM
GTPENGINES's Avatar
WAS LOOKING THIS UP AS WELL DONT KNOW IF ANYONE FOUND THIS BUT HERES THE HONDA TRANSMISSION LIST
http://lonewolfonline.net/honda-civi...mission-guide/
Old Mar 18, 2012 | 06:40 AM
Former User's Avatar
Anyone know why 92-95 Civic manual transmissions are referred to as P20 rather than S20 at the link above?
Old Mar 18, 2012 | 06:45 AM
94EG8's Avatar
Seagull Management
Yes. The case has a P20 cast in it somewhere (exactly where escapes me right now, but I'm going outside later and I have one laying on the floor of the garage so I'll check.) The white sticker says S20 so you'll hear people refer to them as either, but S20 is the more common designation you'll hear.
Old Mar 18, 2012 | 12:49 PM
94EG8's Avatar
Seagull Management
Default Re: S40-e5f to S20 transmission swap - question about transmission codes
Update. The S20 transmissions have S20 on one of the white stickers and P20 on the other white sticker. They also have P20 cast into the case around the starter hole. S40 units have a P4A stamp in this location.
Old Mar 18, 2012 | 12:52 PM
Good information. Thanks. Will we ever able to decipher the code of those genius Honda engineers?
Old Mar 18, 2012 | 01:00 PM
NOFX's Avatar
H-T White Ops
Only thing I can think of is checking every '88-'00 Civic we come in contact with. Hell, all Hondas.
I've been known to go to Honda to check out the new cars each year, not to look at the cars themselves, but merely the new colors, names and codes. I can't be the only one who does stuff like that.
Rubster-Honda
Honda Civic (2001 - 2005)
Sep 28, 2013 12:24 AM
Jordan Lovell
Apr 26, 2012 09:59 AM
not you
Sep 13, 2007 01:19 PM
delslo93
Nov 2, 2006 08:17 AM
