Converting from OBD2=>OBD1 on a GSR
Old Oct 5, 2002 | 12:32 PM
A SpooN FED GSR's Avatar
Default Converting from OBD2=>OBD1 on a GSR
i was trying to do some research on this topic. but i was wondering if anyone here has changed from OBD2 to OBD1 and if so. what are the significants of doing so?
with a p72 obd2 to p72 obd1.
thanks.
Old Oct 5, 2002 | 02:18 PM
MooreBoost's Avatar
Default Re: Converting from OBD2=>OBD1 on a GSR (A SpooN FED GSR)
It doesnt code for a punched out cat. And someone makes a harness for the swap, not sure who though.
gmoore
Old Oct 5, 2002 | 02:25 PM
PaChiLa Leader's Avatar
here is the link for you ...
https://honda-tech.com/zerosearch
Old Oct 5, 2002 | 03:00 PM
baonest1's Avatar
Default Re: Converting from OBD2=>OBD1 on a GSR (gmoore379)
gmoore
hmm... i have a obd2 teg but runnin a obd1 system, so your saying my 2nd O2 sensor will not be mesing me up.
good deal
Old Oct 5, 2002 | 04:05 PM
Skunk_it's Avatar
Default Re: Converting from OBD2=>OBD1 on a GSR (baonest)
The system I'm gonna do is called hondata I'm using a p28 out of a civic. A good place for info on these systems is http://www.hondata.com or http://www.modacar.com their is a tech line you can call for information.
Old Oct 5, 2002 | 05:50 PM
piatl7il77's Avatar
Default Re: Converting from OBD2=>OBD1 on a GSR (GS-Right)
Old Oct 5, 2002 | 11:28 PM
KTeller8's Avatar
Default Re: Converting from OBD2=>OBD1 on a GSR (piatl7il77)
see sig. i got your harness. also have a set of 1.8 cam gears from skunk2 blue brand new.. i opend the box and found out i had the wrong set sent to me. i have a h22 and the 1.8 go with the h23 also. so i am stuck with them. i am asing 165 to shipped. i ll put them in a prioerty big envelope.. i am sure two gears will fit no problem . that will cost 3.89 or something
[Modified by KTeller8, 12:15 AM 10/7/2002]
Old Oct 6, 2002 | 05:34 AM
TimoneX's Avatar
New User
Goin' for the S200 setup GS-Right?
Old Oct 6, 2002 | 02:53 PM
Blown90hatcH's Avatar
I have your harnesses. I make the harnesses. I use all brand new OEM pieces. PRice is 170 shipped in the states. Hundreds built and sold. CHeck out this thread for pics and info:
https://honda-tech.com/zerothread?id=251908
Jason
ultrablackhatch
Mar 17, 2007 11:57 AM
maka
May 27, 2005 12:05 PM
ludests
Nov 14, 2003 10:23 PM
ksilaphet
Jul 19, 2003 05:31 PM
