difference between obd1 and obd2
Old Mar 17, 2007 | 11:02 AM
ultrablackhatch's Avatar
Default difference between obd1 and obd2
I currently have a 97 civic with a gsr swap. My friend gave me his obd1 b16 motor. Can Anyone tell me if I can use some parts from the obd1 b16? Like head block cams etc. Thanks
Old Mar 17, 2007 | 11:57 AM
civicstar's Avatar
Default Re: difference between obd1 and obd2 (ultrablackhatch)
all the parts are interchangable, the gsr head has a higher compression ratio, the gsr cams are a little better, the gsr has a girdle on the bottom end, the OBD1 and OBD2 difference is mainly the wiring and sensors, like Crank positioning sensor on 0BD2 and there are 2 o2 sensors on OBD2. i personally think that GSR is better, what u can do is just get an OBD2 - obd1 jumper harness to convert the ecu to 0BD1 and get a P28. the OBD1 p28 has more flexibility for tuning and IMO the OBD2 has too many sensors that are really not needed unless for emissions
mindless4banger
Engine Management and Tuning
Feb 28, 2016 12:50 PM
shiux
Aug 2, 2009 05:48 AM
Bngo731
Jan 9, 2006 06:00 PM
Ge.ES.AHH
Sep 21, 2004 04:56 AM
95integragsr1984
Dec 15, 2002 11:53 PM
