quick ecu question/suggestions
I recently picked up a 98 hatch with a b20z2 block and ls head
Guy i got it from said it was running a chipped p28 and he said the chip is messed up and that's why it runs rough
It idles between 800 and 1500 and constantly fluctuates
And when i drive it feels unless i give it some gas it's cutting out like im barely pushing the gas pedal
Is it possible its not the ecu?
Should i get a different ecu if that's the problem?
Any help greatly appreciated!
Nah no cel. Only light on is the srs but that's it. And I have no clue on the map it's currently on. Is there any way I can tell? Sorry if im asking stupid questions
Then that is where you need to start. Get a ls map burned onto your chip. At this point it will be hard to determine what map is on there since you don't know which program was used.
The idle going from 800 to 1500 back and forth could definately be the IACV. My buddy's running an lsvtec in his integra and it was having the same problem, he changed it out a couple days ago and the problem is fixed.
