had brights on and car turned off
well i was driving home from a buddys house after work, and i had my brights, then the driver headlight just quit workin out of no where. After that i turned my lights off then flipped them back on and they still didnt work. After that i went to push the gas and it bogged down and wouldn't start. I then popped the clutch while i was moving and it ran perfect and then out of no where the radio turned off but the music was still playing and it turned on about 2 minutes later.. Any idea what could have happened? it blew my mind when it happened.
edit: 94 civic sedan dx d15b7
I have also heard of part of the wire harness behinnd the Intake Maniford rubbing on something causing a wire to short out. Never really read into it much, but it's worth a look at.
before u go digging for shorts
make sure to tell us battery voltage in the morning if u can. also start the car if ur able tol and check the battery light in the cluster
well the battery light works for sure i know it came on when the alt. went out and that happened over summer. but the weird thing is the battery light never came on
moleodonuts
16
Jan 17, 2022 09:59 PM
stockcivic103
26
Jan 11, 2006 02:34 AM
