94 civic dx JDM D15B still hesitating after tune up
Old Oct 2, 2011 | 06:32 PM
the soL that could's Avatar
Default 94 civic dx JDM D15B still hesitating after tune up
94 civic dx
JDM D15B
ok... my vehicle is still hesitating. it usually happens when i turn it on and drive out of the parking lot, when cold. after that, it runs like a dream. BUT it does happen when it is not cold.
i have a new ignition coil AND ignition control module... swapped out the ignition switch also. i have new plugs, wires, fuel filter... i have no idea what is wrong with it. it originally had a shut off while driving issue until i changed the ignition switch out, but now it is giving me this problem.
Old Oct 2, 2011 | 07:40 PM
Former User's Avatar
Default Re: 94 civic dx JDM D15B still hesitating after tune up
ignition timing?
Old Oct 3, 2011 | 02:23 AM
Dioxine's Avatar
If it also does it at random i would check to make sure all the internals in the dizzy are tightened down good and check for damaged wires. Another thing it could be is a leaking map sensor. Im throwing this out as the first little bit that the car is running the o2 sensor isnt sending information until it reaches its operating temperature (Honda's use a map and o2 sensor to help deliver fuel instead of a maf) so check you o2 sensor to.
Old Oct 3, 2011 | 10:06 PM
yes... all tight. i made sure the connections had a bit of drag before i installed. my screws are held in with loctite also.
how do i check the map sensor?
also, how do i check the o2? i ask because i never had an o2 fail on me without a CEL showing up. i have no CEL, so i do not even know where/how to look.
Originally Posted by RonJ@HT
ignition timing?
my vehicle does idle a bit strange... but i think it is in my head. i will check this ... hope i do not have to purchase a timing gun. i am going broke here.
Old Oct 3, 2011 | 10:10 PM
Go_Race_Your_Self's Avatar
Two Piece
Whats it idle at at first cold start up and at operating temp?
Kev
Old Oct 4, 2011 | 10:50 PM
Kev
i do not have a anything to gauge my RPMs... vehicle is an automatic and the speedo/tach only has temp, speed (mph), and fuel... the idle is consistent but there is a humming noise that goes:
hummmmmm, hummmmm, hummmm, hmmm, hmm, and repeats itself... that probably makes no sense... lol
Old Oct 5, 2011 | 01:15 AM
HondaPartsHero's Avatar
Technical Hero
Is your check engine light on?
Old Oct 5, 2011 | 07:33 AM
Two Piece
The humming noise you are talking about, it sounds like the RPMs are going up and down constantly?
Kev
Old Oct 5, 2011 | 07:42 AM
nope... sometimes, i wish it was though... so at least i know what the issue is.
Kev
yeah... but it isn't too noticeable. i think it is timing related.
Old Oct 5, 2011 | 07:53 AM
Two Piece
Most likely not timing. Check your coolant levels and check you IACV and TPS.
Kev
endless22
Dec 7, 2011 11:28 PM
Atomic_EF9
Jul 3, 2011 03:24 PM
Glades Ghost
Jan 29, 2011 05:26 PM
flatblacksleeper
May 8, 2009 11:27 PM
Jorsher
May 2, 2006 05:09 PM
