Uneven firing
Old Sep 30, 2011 | 06:53 AM
hispanic panic's Avatar
Default Uneven firing
I think my cylinders aren't firing evenly. Its very light and is only noticible in low RPM's. Again, its not always noticible. I can only notice it during acceleration below 2500 rpm in 1st or 2nd gear. I havn't pulled the plugs yet to check them, but how likely is it that i need to replace the ignition coil?
Old Sep 30, 2011 | 07:22 AM
Steve Z's Avatar
Default Re: Uneven firing
Hard to say without hearing it. I doubt it's firing unevenly, but rather it's misfiring intermittently. It could be the EGR ports are clogged a bit?
Old Sep 30, 2011 | 07:24 AM
I was thinking of running some seafoam through the vaccume lines. which line do i need to feed it through?
Old Sep 30, 2011 | 07:33 AM
Steve Z's Avatar
Break booster vacume line. You'd be better off to just clean the egr ports. MHO.
Old Sep 30, 2011 | 07:41 AM
how do i do that?
Old Sep 30, 2011 | 08:00 AM
and btw i have a 98. I've only seen egr cleaning threads about 97 and below, so maybe egr port clogging isn't an issue for 98+??
Old Sep 30, 2011 | 08:08 AM
I noticed this thread
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-internal-seal-distributor-internal-oil-leak-2214402/
I am in fact leaking oil from what seems to be the distributor seal. I think its only leaking from the outer seal, but how can you tell if its coming from the inner seal?
Old Sep 30, 2011 | 08:59 AM
GhostAccord's Avatar
Remove the distributor cap and there would be oil inside the distributor housing. There is a small weep hole at the base of the distributor (facing down toward the trans) that would have oil dripping from it as well.
Old Oct 19, 2011 | 01:45 PM
I replaced the o-ring on the shaft of the distributor, which seemed to help, but i'm still leaking from somewhere. I talked to a mechanic and he said that there is an additional o-ring that is located inside the block, behind the distributor. Is this true?????
Old Oct 20, 2011 | 01:41 AM
If you unbolt the distributor and pull it out from the engine there is an O ring there as well.
Old Nov 12, 2011 | 12:05 PM
OK so i've been dealing with this issue for a while now, and it is significantly worse. The uneven firing turned into zero power. Sometimes i completely loose power, and the only way to regain it is to floor it, or let off the pedal and accelerate again. When it looses power, it feels like there is a huge deadspot in the middle 80% of the throttle range. It works fine sometimes, then starts acting up. I'm constantly having to floor it everywhere, staying in high gear so ppl don't think i'm speed racer.
I thought it was the tps acting up, so i ordered a new throttle body off ebay, and its still doing the same thing with the new TB. The TB came with the tps and map sensor all intact.
Is it possible i'm having fuel pressure issues?? If that was the case, wouldn't starting the car become difficult?? Cause it starts right up every time..... and at WOT it performs like it should...
I also put half a can of seafoam through the brake booster, and a full one in the tank. Didn't change a thing.
Old Nov 13, 2011 | 09:42 AM
chikin pickle's Avatar
Check your throttle position sensor. Sounds like it has a dead spot in it.
Rahzel00
Aug 7, 2015 03:41 PM
The-obd0-one
May 4, 2010 10:09 AM
ef-b16sedan
Aug 9, 2006 07:34 PM
redpeppers
Jun 11, 2006 08:24 AM
Beave0101
Dec 18, 2002 06:54 PM
