Do EK9's have a dimmer switch?
I was looking at this front clip and noticed the pocket where our US market civics have a dimmer switch. So do EK9's have a dimmer located elsewhere? To me this option seems useless so I'm thinking about buying a pocket vent that way I can stick a cellphone or something in there.
I have a 98 civic ex with a CTR cluster and I notice when i use my dimmer the cluster doesnt dim like the stock one did, so im guessing ctr didnt dim at all
Correct, even if you use a JDM cluster in a USDM car the cluster wont be affected by the dimmer, they stay very dim.
EK9's do not have dimmer switches. The cluster does not even have a dimmer circuit. any bulb for illumination will have full battery voltage to them without any effect if you try to adjust your dimmer. It's as bright as the Si's amber at full brightness.
[713]
Nov 1, 2012 04:12 PM
peacexisxfree
Oct 21, 2005 01:06 PM
