Z6 head d15b bottom end timing issues help
Old Sep 27, 2011 | 02:21 PM
Frost7177's Avatar
Default Z6 head d15b bottom end timing issues help
I have a 97 Honda civic and it's running like crap has no power up to 3 grand once three grand hits it starts building power until 6 grand and redlines . I'm thinking the timing is off but I don't have any timing covers to check my timing on the motor can someone give me some advice .
Old Sep 27, 2011 | 02:39 PM
92lxsleeper's Avatar
Default Re: Z6 head d15b bottom end timing issues help
do you have an adjustable cam gear?
Old Sep 27, 2011 | 03:58 PM
crx^2yosolo's Avatar
Wow right of the bat I can tell you 97 civic has crank angle senser!! If this not connected your car is going to run Like crap!
How you fix this ! You need crank angel sensor of 97 n up D. And oil pump.
Because d15 doesn't have the sensor or screws to mount the sensor.
Remember ANY PART FROM any D fit any D !
Old Sep 27, 2011 | 09:03 PM
Frost7177's Avatar
Your right about the crank sensor im running a obd1 dizzy doesnt that run off of timing? Could it be that im running the 97 ex ecu instead of the obd1 p28 i should run
1993 EG Coupe
Aug 18, 2014 09:13 PM
tougeem2
Nov 15, 2011 05:39 AM
EF9_TryMe
Oct 18, 2010 10:32 AM
WhippinTheLude
Oct 20, 2004 06:33 AM
sircrxracer
Mar 10, 2004 09:06 AM
