installing manual transmission
Old Sep 26, 2011 | 12:24 PM
bdmlilburn's Avatar
Default installing manual transmission
ok in the past i have removed and reinstalled n automatic transmission onto a 96 accord.
i am having trouble on my cb7 however. i just cant seem to be able to get the manual transmission back on the engine. already removed the engine and transmission to install jdm engine. jdm engine is installed and i have the manual transmission up in the hole but i cant seem to be able to get it to sit flush against the engine. i have three bolts in the top but the bottom side just dont wanna move...
any tips or ides on what i could be doing wrong would be greatly appreciated i have to get this done by friday
also i did use the clutch alignment tool and insert it full through the clutch to the engine before tightening all the pressure plate bolts down
Old Sep 26, 2011 | 04:11 PM
chikin pickle's Avatar
Default Re: installing manual transmission
Is your throwout bearing and clutch fork properly installed?
Are the transmission dowel pins in good condition?
Try removing the transmission and all the bolts. There are precision dowel pins there, if the don't go in straight they don't go in. I bet they are either damaged or misaligned.
Old Sep 26, 2011 | 04:58 PM
accordmatt's Avatar
wait wait wait he said a auto to manual tranny. if u are swapping the auto for a manual u are not gonna be able to just swap w/o different mounts. l did a auto- 5speed swap over a yr ago and l had to have custom mounts because the tranny and driver side motor mounts are different. u have to cut the ear out of the engine bay and reweld in a manual ear for the motor mount to sit into.
Old Sep 26, 2011 | 06:39 PM
Assume he knows what he's doing. The bellhousings are the same and that's what he's talking about.
Old Sep 26, 2011 | 06:56 PM
accordmatt's Avatar
correct housing is same but well actually a auto housing and manual housing are different. a auto is bigger and bulkier. manual is alot smaller and lighter but they have different mounting. a manual tranny motor mount wont align with a auto ear in the engine bay
Old Sep 26, 2011 | 06:59 PM
I know, but the bellhousings are the same. Otherwise a manual tranny wouldn't fit on an automatic block etc. Physically the automatic transmission is larger. But he's not swapping anything.
Old Sep 26, 2011 | 07:05 PM
accordmatt's Avatar
ok in that case if ur having that much issue getting trans in. i know its alot of work kinda but l did my swap with trans mounted only took 30 mins to manuever into place and aligned right up. only other advice is take everything out of ur way if u havent already. ive seen it done many ways just sit down when u got time and get a extra knowledgable hand and u will eventually get it bro
Old Sep 26, 2011 | 08:51 PM
holmesnmanny's Avatar
The only real problem you'd have is if the dowels pins are either not there or are scratched up really bad. There are two. What I had to do is oil them really good to get the tranny to slide onto them. This was after I scratched up the first batch so bad that the tranny wouldn't slide on the first time.
Also, for those that are removing the entire engine the clutch alignment tool isn't really necessary since you can actually see it line up with them off the car. If you just put on the tranny an alignment tool is helpful because you can't exactly get your head in there to see if it all lined up correctly enough to get the transmission on flush.
Old Sep 27, 2011 | 12:20 PM
SQ is the SQUAD's Avatar
make sure there are 2 dowel pins in the same location. did that before. one stuck in the block, when i put the new tranny on the tranny already had one in that spot.
i guess its safe to assume that you did install a flywheel and clutch set up on the block.
Old Sep 28, 2011 | 09:04 AM
bdmlilburn's Avatar
yes installed a findanza flywheel along with a new pressure plate and clutch disc. the dowel pins look to be ok. this thing just dont wanna sit straight got two more days to figure it out before the land lady tows it
gonna try and maybe figure out a better way to get the lift on it perhaps....
Old Sep 28, 2011 | 11:20 AM
Take the dowels and swap them to the tranny if they're in the block or vice versa and be sure to oil them. Make sure they're in the correct spots.
Davesmit
Jul 5, 2023 04:36 AM
LimpSalamander
Jan 9, 2019 12:24 PM
Suthe245
Oct 19, 2016 05:04 AM
Goodbye My Love
Sep 29, 2005 02:57 PM
TommyBB
11
Sep 5, 2005 06:53 AM
