replace or rebuild b16a2???
have a 2000 SI^^^^thats the question ive been looking around and cant find any answers. so (for future references) would it be better to replace my b16 with another b16 or rebuild it when needed? they are both are around the same budget. i just want to know what would be best.
replace it with one with 40,000 miles or rebuild the one with 160,000??
Depends what's wrong with it. I spun a bearing and rebuilt, and mine failed again within 100 miles. Of course it can be done right... but there's room for error. Machine shop apparently didn't do a perfect job on the block.
I'd try and grab a B18 instead, when the time comes.
rebuild it early before anything happens to it, and you're good as gold. Or what I would do is find another b16 bottom end (they are cheap and easy to find as people like to take the heads for ls/vtec) and rebuild it while you're still able to drive.
Well there is something wrong with it now but have to see or check it out with my mechanic to see what. I don't know what it is. But just in the future in case its major like a thrown rod and put a hole in the block...would it be good to replace the block, pistons, rods etc. Or get a whole engine??? Also the head on my engine now has about 10,000 miles on it if that tells you anything. I have a thread under tech/misc if you want to know what my car is doing but I'm just trying to get ideas that's all
If it's knocking, get a new bottom end to keep it easy (i'm not searching to see what it is, sorry, but not tonight). b16 bottom ends are easy to find. or upgrade to a b18b bottom end (even easier to find) and look into an LS/VTEC setup.
ok so rebuilding it would be the better way to go and just find another b16 bottom end or a b18b and it all should just fit into place. ok cool. will the stock ecu work on the b18 block? or is that just a dumb question? im new to some engine electrical stuff but i know the mechanical of the engine.
That means jumping to obd1, buying a new ecu having it chipped/tuned.
Rebuilding will be cheaper, but you'll be out of commission for 2 weeks minimum. Figure at least a day to pull you engine out, at least a day to disassemble the motor and get it ready to take in. Machine shops usually have a good week or two wait between getting your stuff and getting it back to you. Then assembly takes a day or two, same with the install.
You would be better off finding a second block. Either another B16 block or a B18, even a B20 block and doing an LSVTEC. B16 will be the easiest option and you won't have to drill and tap your head...some people are squeemish about that.
You will not be able to use your ECU. You'll have to get an OBD1 ECU, aftermarket tuning software and either tune it yourself or have someone else tune it.
post a link to the thread you were talking about. If you want us to read what your car is doing, don't expect us to search for it.
Could a P72 run a B16 head on a B18C bottom end? It will definitely run, almost anything will run on almost any ECU. To get the most out of any engine, you should tune it, it's free horsepower especially if you do any modifications.
Damn near any Honda ecu will start and run the car. Will it run good? Not likely.
****, I could start my friend's ITR with my ECU if I wanted to.
If its a bottom end knowck could be bearings could be something else. I am a big fane of cylinder leakage tests to shot the condition of the cylinder walls rings and valve seats which should be good if the head is new).
If it just needs new rod and crank bearings that should be easy. If it spun a bearing you would need to get it line bored by a good machine shop (probably easier to get a new block). If there is cylinder wall damage you would need to look at either sleeving it replacing it or going oversized pistons and boring and honing it. If the cylinder bore iis off by a couple thousands you will need to rebuild again.
I would recomebd doing some more dudilligence on determining what is wrong. If it seems to be a major bottom end issue I would recomend tearing it down. You can plastiguagwe your crank and main bearings to check them out and should be able to feel any wear that is excessive on the cylinder walls.
ok cool. now would there be any major modifications or differences on the b18 block that i would have to recognize for the b16 head to go on? or would it just be a straight drop in easy swap?
Info on ls/vtec (b18a/b w/ vtec head) or b20b/z with vtec head can be found here
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
4 year old thread
What the ****? Step 1: Make your own thread. No one likes a threadjacker. Step 2: Don't bump ancient ******* threads without a damned good reason. You don't have one. Step 3: Read the rules sticky, and the FAQ sticky. They're stickied threads for a reason.
nix94delsol
Jun 7, 2007 09:01 AM
mountaindewguy
Dec 7, 2005 07:53 PM
