ls/vtec civic head gasket.
Old Sep 22, 2011 | 03:28 PM
titan101's Avatar
Default ls/vtec civic head gasket.
my ls/vtec in my 96 ek doesn't seem to like head gaskets anyone know why or a solution?
Old Sep 22, 2011 | 03:30 PM
98civdx's Avatar
Master Detailer
Default Re: ls/vtec civic head gasket.
What do you mean it doesn't like head gaskets? What type are you using?
Is your engine detonationg? Are you overheating? Have you check the block and head to see if they're warped?
Old Sep 22, 2011 | 03:34 PM
grumblemarc's Avatar
The Grumpiest
You're either using the wrong ones or installing them incorrectly. Even still, with lack of information it's hard to say. If you're boosting possibly you need ARP headstuds.
Old Sep 22, 2011 | 09:24 PM
titan101's Avatar
all stock. i just keep getting oil from around the head gasket. Using non vtec gasket.
Old Sep 22, 2011 | 09:42 PM
Texas4door's Avatar
Oil eh?
You mean oil is mixing with the coolant or oil is actually seeping out from between the head and the block?
If it's the latter...I'd say either the block/head is warped, or the wrong gasket is being used.
You using OEM head gaskets or aftermarket?
You using any sort of copper spray gasket sealer for the head gasket to help it seal?
Old Sep 23, 2011 | 06:50 AM
98civdx's Avatar
Master Detailer
What Headgasket are you using??
If your using the non vtec headgasket are you removing the rivets in it?http://www.goldeneaglemfg.com/includ...yGEMgasket.jpg
Old Sep 23, 2011 | 07:18 AM
fallrivercolin's Avatar
Did you skip a step in the ls/vtec conversion (ie:plug)
Old Sep 23, 2011 | 03:00 PM
titan101's Avatar
oil seeping from gasket. oem autozone non vtec head gasket. plug done right and correct pins. no copper spray.
Old Sep 23, 2011 | 03:48 PM
98civdx's Avatar
Master Detailer
Did you remove the rivits?
lsturbo*
May 6, 2008 07:18 PM
lsturbo*
Apr 30, 2008 04:41 AM
blk90teg
Feb 14, 2007 08:53 PM
CRXGSR
Mar 11, 2003 09:28 PM
InfamousRS
May 27, 2002 02:35 PM
