Can you plug nitrous onto the breather plug on an intake?
Old Oct 4, 2002 | 03:35 PM
armharm's Avatar
Default Can you plug nitrous onto the breather plug on an intake?
Instead of drilling a hole like the instructions say so here... cant you just directly connect it to the breather plug on an intake?? and also, if nitrous is more compressed in higher temperatures, then isnt having a CAI disadvantagous (if thats a word)?
Old Oct 5, 2002 | 07:33 PM
97hb's Avatar
Default Re: Can you plug nitrous onto the breather plug on an intake? (armharm)
Some nitrous kits need a certin length between the t/b and the nozzle. Usually with a wet shot its closer so the fuel doesn't puddle. Dry kits are farther away to evenly distrubute the nitrous in the air so each runner on the intake manifold gets an equal shot.
Old Oct 5, 2002 | 08:39 PM
MikeMAN's Avatar
Default Re: Can you plug nitrous onto the breather plug on an intake? (97hb)
if its the dry kit, that will be wayyy too close to the intake manifold, it needs to be anywhere from 12-18 inches away (depends on kit)
good luck!,
mike
95dc2teg
May 23, 2009 08:25 PM
WhiteEJCoupe
Nov 25, 2008 06:55 AM
5spdIntegra
Oct 19, 2003 12:00 AM
EGkTiOn_CiViC
Dec 22, 2002 03:51 PM
honda8882
Jun 14, 2002 02:14 PM
