Plug Nitrous Holes??
Old Nov 24, 2008 | 03:29 PM
WhiteEJCoupe's Avatar
Default Plug Nitrous Holes??
well i bought a setup from my boy who was doing a direct port nitrous setup....he gave me the edelbrock manifold with the setup....now it has 4 tapped holes in the runners for the direct port....
im not running nitrous so whats the best way to plug the holes? would a threaded plumbing plug like this work? just put teflon tape around it and screw them im the holes?
Old Nov 24, 2008 | 03:37 PM
paton5g's Avatar
as long as the holes are totally sealed shut, i don't see what the issue would be. go for it boss.
Old Nov 24, 2008 | 03:38 PM
figured if the nitrous nozzles hold in the air this has to?
sucks, i dont fell like going through the process of trying to trade it
Old Nov 24, 2008 | 03:43 PM
m R g S r's Avatar
use em and get a bigger turbo...the nitrous will help spool :D :D
jk but yeah that should work fine.
Old Nov 24, 2008 | 04:01 PM
rota92
Guest
Posts: n/a
So long as the thread is right and the threads arent messed up you'll be fine with putting a pipe plug in.
If the threads are trashed, or not enough thread for your liking you can have them welded shut and just smooth the runner inside. I had to run smaller nozzles than my old manifold was set up for, so we welded some material in and drilled it for the smaller size. Then plugged that until I got around to using them...err thought I was going to use them lol
Old Nov 25, 2008 | 06:55 AM
truu...ill see what i can do...i rather just plug incase i want to put the nitrous back in
j0keefe21
Dec 20, 2009 01:20 PM
civicrights
Dec 1, 2003 08:31 AM
armharm
Oct 5, 2002 08:39 PM
