problem rpms
Old Sep 18, 2011 | 03:41 PM
cholder919's Avatar
Default problem rpms
with the car in park I seen the rpms go to 2 then drop to 1 costantly, the car is reving up and down just sittiing there, i hit the brakes hard the car rpms drops to zero then cuts off but if i hit the gas then it doesnt cut off. if i tapon the brakes and coem to a stop it doesn't cut off
Old Sep 18, 2011 | 08:08 PM
75aces's Avatar
Default Re: problem rpms
Maybe a bad tach? Did you get a cel?
Old Sep 18, 2011 | 08:15 PM
nus_dogg's Avatar
So it's surging?
Old Sep 19, 2011 | 06:34 AM
cholder919's Avatar
whats a bad tach? it surges as soon as I cut the car on
Old Sep 19, 2011 | 06:45 AM
75aces's Avatar
The tach is inside the cluster housing and can be swapped out. Over time, the units will fail and can be replaced with a different unit. My speedo went bad and I just got a different speedo and it started working again.
Old Sep 19, 2011 | 09:14 AM
cholder919's Avatar
I got a new speed sensor two weeks ago problem still happens.. can this be symptoms of a bad ignition module or fuel pressure regulator?
melancollie
Mar 2, 2012 10:35 PM
*Boostwerks*
Jul 5, 2006 06:40 PM
Nihilus
Dec 18, 2005 01:28 AM
cyberjunkie
Aug 5, 2004 04:00 PM
Milano97
Jul 11, 2004 05:28 PM
