Random blue sensor with no plug on back of HX block?
From: New York in the summer, South Carolina in the winter
While changing the oil on my civic HX I noticed a sensor that had no plug in it on the back of the block. I looked all over but did not see a plug for it. Anyone know if this is normal? It looks like a knock sensor and is blue.
Mine is 5 speed. It is not the oil pressure sending unit- no CELs or codes.
Thank you all for responses they are much appreciated
Yes original engine car has never been modified or anything of that nature- I really think its a knock sensor but am confused why there is no wiring for it? The plug also appears to be quite clean which makes me believe the plug wiring fell off recently but it is no where to be found...
Just wondering if that is a knock sensor if someone swapped blocks (or engines) out at some point in time in the car's history
