Type R cams on stock GSR valvetrain...?
Old Oct 4, 2002 | 01:06 PM
B19CivicHB's Avatar
Default Type R cams on stock GSR valvetrain...?
Is it safe? Im not really looking foreward to changing the entire valvetrain to ITR stuff... but the cams are easy. Thanks,
-Nick-
Old Oct 4, 2002 | 01:20 PM
gsrvx's Avatar
New User
Default Re: Type R cams on stock GSR valvetrain...? (B19CivicHB)
As long as u don't raise ur redline...you'll be fine.
-Rod
Old Oct 4, 2002 | 03:36 PM
MikeSarr_GSR's Avatar
Default Re: Type R cams on stock GSR valvetrain...? (RK)
dont miss a shift or say goodbye to your exhaust valves.
Old Oct 4, 2002 | 03:59 PM
Jared's Avatar
-Rod
yup
Old Oct 4, 2002 | 04:18 PM
IN VTEC's Avatar
I'd be glad to help you out if you did want to do the whole package.
Old Oct 4, 2002 | 04:58 PM
DefiantGSR's Avatar
move your stock gsr dual intake valvesprings over to the exhaust side and get dual ITR valvesprings for your intake side...you'll be fine with that.
Old Oct 4, 2002 | 07:08 PM
Rob Dizzle's Avatar
Default Re: Type R cams on stock GSR valvetrain...? (DefiantGSR)
err not really
You will also want to get the itr lost motion asemblys, they should run about 250 from the dealer.
btw, in case you dont know, he meant dual itr valve springs, as in outer (bigger) and inner (smaller) springs for the intake portion
get a hondata, cam gears, and bump up your compresion, you should make 180 ish whp
Old Oct 4, 2002 | 07:43 PM
DefiantGSR's Avatar
Default Re: Type R cams on stock GSR valvetrain...? (Bob-DC2)
that info i got from a good reliable source..some of you may know him as tuan at many honda forums or micheal delaney at team-integra.net....i believe he is a reliable source...do you?
[Modified by DefiantGSR, 4:46 AM 10/5/2002]
Old Oct 4, 2002 | 09:00 PM
B19CivicHB's Avatar
Im running 12.5:1 CR with the stock head right now. Hondata unit is on it's way along with cam gears and a FPR.
Old Oct 4, 2002 | 10:31 PM
xtrafastcivic's Avatar
you guys make like changing vavle springs is a 5 minute affair...
if you put itr cams in your gsr you can run them with stock gsr redline...
but vtec engagement won't be at the right place so from 4400 to 5700 there will be a dip in power...
Old Oct 5, 2002 | 01:44 AM
GZR4DR's Avatar
Default Re: Type R cams on stock GSR valvetrain...? (XtraFastCRX)
Just drop them in if your not planning on raising the redline. Screw the ITR lost motion assembly unless you get it for free. I used the GSR one and made plenty of power in the motor in my sig. Get a vtec controller and set the x-over to 5K for driving on the street. Right now i have a B20-vtec with ITR cams. I haven't bothered upgrading the valvetrain because i am running a stock GSR ecu. Therefore i don't need to change them.
Also to the person that said don't misshift. I would agree that misshifting with any car and any set of cams can have bad consequences.
Dwizzy
Aug 30, 2008 01:16 PM
ajbucci
12
Mar 8, 2006 08:20 AM
usher13
Feb 13, 2003 10:30 AM
IgniteTeg
Jun 30, 2002 02:03 AM
yellowbuffalo
Jun 16, 2002 02:33 AM
