Type R cams on stock GSR valvetrain...?
Is it safe? Im not really looking foreward to changing the entire valvetrain to ITR stuff... but the cams are easy. Thanks,
-Nick-
-Nick-
Re: Type R cams on stock GSR valvetrain...? (B19CivicHB)
move your stock gsr dual intake valvesprings over to the exhaust side and get dual ITR valvesprings for your intake side...you'll be fine with that.
Re: Type R cams on stock GSR valvetrain...? (DefiantGSR)
You will also want to get the itr lost motion asemblys, they should run about 250 from the dealer.
btw, in case you dont know, he meant dual itr valve springs, as in outer (bigger) and inner (smaller) springs for the intake portion
get a hondata, cam gears, and bump up your compresion, you should make 180 ish whp
Re: Type R cams on stock GSR valvetrain...? (Bob-DC2)
that info i got from a good reliable source..some of you may know him as tuan at many honda forums or micheal delaney at team-integra.net....i believe he is a reliable source...do you?
[Modified by DefiantGSR, 4:46 AM 10/5/2002]
Im running 12.5:1 CR with the stock head right now. Hondata unit is on it's way along with cam gears and a FPR.
you guys make like changing vavle springs is a 5 minute affair...
if you put itr cams in your gsr you can run them with stock gsr redline...
but vtec engagement won't be at the right place so from 4400 to 5700 there will be a dip in power...
Re: Type R cams on stock GSR valvetrain...? (XtraFastCRX)
Just drop them in if your not planning on raising the redline. Screw the ITR lost motion assembly unless you get it for free. I used the GSR one and made plenty of power in the motor in my sig. Get a vtec controller and set the x-over to 5K for driving on the street. Right now i have a B20-vtec with ITR cams. I haven't bothered upgrading the valvetrain because i am running a stock GSR ecu. Therefore i don't need to change them.
Also to the person that said don't misshift. I would agree that misshifting with any car and any set of cams can have bad consequences.
ajbucci
12
03-08-2006 08:20 AM
cam, cams, camshafts, gsr, itr, redline, requirements, springs, stock, train, type, valvatrain, valve, valvetrain, vtec
