gt3076r vs turbonetics hp66
Old Sep 14, 2011 | 10:00 PM
JSTANOTHERHONDA's Avatar
Default gt3076r vs turbonetics hp66
Want to see what some of you turbo gurus think, currently I'm running my setup on the gt30 and thinking of going to the HP66 all input welcome .
Old Sep 15, 2011 | 06:51 AM
Schister66's Avatar
Man U FTW
Default Re: gt3076r vs turbonetics hp66
I dont claim to know anything about the Turbonetics turbocharger, but from what i've seen of Turbonetics in the past, I would never switch from a Garrett to a Turbonetics. They seem so second-rate. If you notice, you dont ever see threads spouting about how amazing anything Turbonetics is...I would stick with what you have
If you really feel like swapping turbos, might I suggest a Borg Warner S258. It will spool about the same as your current GT30r, but is capable of a lot more power if you keep upping the boost. Also, they sound amazing
Old Sep 15, 2011 | 08:28 AM
TheShodan's Avatar
Moderator
Or upgrade the GT3076R with something else while keeping the internal structure of the GT3076R. There are several options.
Old Sep 15, 2011 | 11:26 AM
DaFredsta's Avatar
he has a gt3076r already on his setup, his goal is 650-700hp which the gt3076r wont be able to produce since it maxes out around 550hp, the turbonetics snail would work great for his setup and he will hit his goal no problem just my .2cents
Old Sep 15, 2011 | 12:31 PM
TheShodan's Avatar
Moderator
Well, then he has to be wanting a completely different setup over this. The two turbos are of completely different airflow rates and purposes.
Old Sep 15, 2011 | 02:57 PM
I guess ill just have to check out some air flow charts and compare the one worry of mine is lag.
Old Sep 16, 2011 | 04:10 AM
shawty22's Avatar
If your looking to get rid of your 3076r ill take it off your hands.
Old Sep 16, 2011 | 06:59 AM
Shot you a pm.
Old Sep 17, 2011 | 06:34 AM
fast2camciv's Avatar
650-700hp is the goal, and your worried about lag?! I'm pretty positive lag on a honda is the one constant at 650-700hp lolol
Old Sep 17, 2011 | 10:32 AM
Schister66's Avatar
Man U FTW
Next time you're looking for turbo advice, it might be nice to have a goal listed. While we were giving you options similar to your GT30r, you needed something completely different.
You can have relatively less lag from one turbo to the next, but at tht power level, lag is the one constant (i had to borrow that phrase)
Old Sep 17, 2011 | 01:49 PM
Turbo-LS's Avatar
Took the words right out of my mouth LOL !
Old Sep 18, 2011 | 07:22 PM
Well yes my goal is about 700. And yea I guess you guys are right about the lag thanks for the info though.
Here is my set up.
84 mm ls darton sleeves
Cp 9:1 pistons
Eagle rods. Stock crank.
Port flow b16 head with ctr cams
Victor X manifold
255 walbro w/ Bosch 044 inline
Pte 1000 injectors
S300
With a lovefab manifold 3" dp
Old Sep 18, 2011 | 07:59 PM
Turbo-LS's Avatar
IMO pick up a 6265 precision billet unit. will get you over 700whp and still spool decently and give you a ncie powerband. the 6262 will also allow for 700range just take a little more boost to do it
Freshdot
Mar 6, 2013 05:15 PM
airwalk07143
Sep 19, 2009 09:10 AM
YesSiR
Apr 30, 2008 07:23 AM
greasemonky50
Mar 15, 2006 04:40 AM
pip9
Dec 18, 2003 03:59 PM
