Ignition Problem
Old Oct 4, 2002 | 10:50 AM
Hondasaurs's Avatar
Default Ignition Problem
Im getting a code 15. I replaced the ignitor and the car still runs like crap. Im getting a spark to all of the cylinders. I also replaced the spark plugs. What could be causing this?
Old Oct 4, 2002 | 01:42 PM
Chiovnidca's Avatar
Default Re: Ignition Problem (ZC_CRX)
Are all the connectors on the igniter good and tight?
Old Oct 4, 2002 | 07:55 PM
Hondasaurs's Avatar
Default Re: Ignition Problem (Chiovnidca)
all of the connectors are tight. could it be the fuel injection or possibly a bad distributer?
Old Oct 5, 2002 | 02:58 AM
Chiovnidca's Avatar
If your still getting a code 15, and you know the igniter is good, then it's time to to check the rest of the wireing and connectors back to the ECM. Have fun.
Old Oct 5, 2002 | 07:43 AM
Jared's Avatar
does the coil check out?
Old Oct 6, 2002 | 10:11 AM
Hondasaurs's Avatar
Default Re: Ignition Problem (Jared)
i traced the problem. It turned out to be mixed up vacuum lines at the MAP sensor. Now thew car runs fine but I have irradic idle. Up and down between 1500 and 800 rpm. Now im getting a Code 5 MAP, which I just replaced, and a Code 13 BARO pressure. How can I get ride of these codes and get the car to idle normally again?
****The car was turbocharged, but I blew a seal in the turbo now the header is on again. These codes appeared immediately.
Old Oct 6, 2002 | 10:13 AM
Hondasaurs's Avatar
Yes, I also replaced that with the ignitor.
dump3deg6
Jul 20, 2009 09:43 PM
lax1089
Apr 19, 2007 11:02 AM
TegProject
Mar 4, 2007 06:28 PM
IWearMyKswiss
Sep 17, 2004 09:49 PM
KimChiKid
Aug 10, 2003 05:37 AM
