Oil leak by distributor...Help Please!
Old Sep 9, 2011 | 03:38 PM
eternalist's Avatar
Default Oil leak by distributor...Help Please!
I got oil leaking from my 99 prelude. Sludge mostly in between engine and distributor. What should I pay to get this fixed? Or is this a quick diy?
Old Sep 9, 2011 | 03:42 PM
oneprelude's Avatar
Default Re: Oil leak by distributor...Help Please!
Pretty sure it's the o-ring, go to the dealership for that
Old Sep 9, 2011 | 05:21 PM
minilogoguy18's Avatar
Stupid easy fix, just get a new o-ring from the dealer, get a 12mm wrench or socket and remove the distributor and replace it.
Old Sep 9, 2011 | 08:59 PM
Wing8806's Avatar
^^ this.
If it does not resolve the issue, than one of the following may be - your cam seal/vtec solenoid seal(s)/ valve cover seal
Old Sep 10, 2011 | 08:13 AM
bennyBronco's Avatar
lmao... everytime i see a post about a leak.. my 5th gen has it. i got a vtech solenoid, oil sending unit, and dist leak.. jst throwing it out there.. your not alone.lmao
Old Sep 12, 2011 | 07:45 AM
typemismatch's Avatar
Honda owns me
Could also be the valve cover gasket, its a bunch of 10mm nuts to pull that off.
Get some Perma Bond at your local parts store and apply it to the valve cover gasket right there where its leaking. Tighten it all back up and be done with it.
This is common and nothing to worry about.
Civiccity03
Jul 17, 2017 04:54 PM
DCAR
14
Jun 24, 2012 11:12 AM
nemesiskrp
12
Jan 19, 2008 05:15 PM
jam36a
Aug 19, 2006 09:56 AM
Pinhead
Jan 5, 2002 12:29 PM
