B16 ECU on GSR Swap
Car is a 99 Civic LX.
Ok so Not sure how to go about this. I have a GSR motor but b16 ecu. Already have a JG Victor X Manifold on it so will the b16 ecu work? or should i get a OBD2B to OBD2A Jumper and use the GSR ECU. Or should I use the b16 ECU for emission and run a OBD2 to OBD1 jumper and use an OBD1 p72?
Update: Issue is. 2000 GSR ECU has immobilizer. dont have the key chip or the key ring.
eventually you will want to have it tuned. go to phearable.net and get an obd2b to obd1 jumper and a chipped p28. my em1 with gsr swap pulled hard with the p2t ecu, but i wanted it tuned so i got the p28
OK yea that was the route i was planning on going. Do you use your p2t for smog? or do you not have emission control where you are?
Get your ecu chipped and flashed with a gsr base-map. The b16 with its smaller displacement has a leaner fuel map because it needs less fuel than a gsr. If you run a b16 base-map on a gsr, you could potentially lean the engine out and burn it up.
racingant
13
Jun 29, 2005 02:27 PM
