Is it just me, or does my turbo spool slowly?
I have an 89 CRX with a 1.6L DOHC ZC engine. It is build with forged 9.0:1 JE pistons. On it I have a straight T3. It's a very small T3 even. A Stage 1 turbine with a .48A/R housing and a .50-trim T3 compressor wheel. It's on a cast manifold using integral wastegate.
I get my full 10psi in 3rd/4th/5th at 3500RPM. If I go WOT in 1st gear it almost gets to redline before the turbo builds full boost. I was expecting full boost in the 2000s with this turbo. Is this just the nature of the beast? Or should I look for something wrong?
I'm used to my Integra with its GT3076. That one gives me full 30psi by 3500RPM.
Here some pics of what I am using:
Any help/ideas?
Any help/ideas?
Yup way too slow for a t3 check the turbine housing for cracks or loose bolts. Do you have any exhaust leaks? Somethins wrong
Thanks for the input. Looks like everyone agrees that my turbo is not spooling as it should.
I did not suspect a charge pipe leak, but I will see if I can come up with a way to test. I don't *hear* any exhaust leaks either. This is the first time I have used an internal wastegate actuator type. I have it adjust "tight" on the flapper valve, but sure how tight is tight enough.
The only other thing I can add is that even tho the turbo spools slowly, once it does, the amount of power/torque feels appropriate to me for the boost level. It doesn't feel down on power at all.
I would like to keep the internal wastegate for simplicity's sake. Millions of OEM cars use them reliably. I don't see why I cannot.
1JDMDOMINICAN
Dec 28, 2004 07:55 PM
