honda gods please help no vtec!!
Old Sep 5, 2011 | 03:47 PM
cj.crx.'s Avatar
Default honda gods please help no vtec!!
i never needed to become a member because searching answered all of my questions but i cant find the answer to my current problem...
i have a 1989 crx si with obd0 b16a pr3
i have no cel, oil is good wiring is good.. i had vtec on a switch so the solenoid is fine and the screen is not clogged..
still no vtec.. it cracked maybe twice over the past week with no cel but only for a split second and only in 1st gear.. when it vtec engaged around 5 or w.e it fell out by 6.5... im no dummy and mechanically inclined but im stumped only other thing i can think of is my ecu is crap... any help is immensly appreciated..
Old Sep 5, 2011 | 05:29 PM
cj.crx.'s Avatar
Default Re: honda gods please help no vtec!!
maybe the main relay?...
anybody? lol
Old Sep 5, 2011 | 07:35 PM
MISTAGLOCK's Avatar
you should wire in a VTEC light. into the dashboard. check the wire going from the ecu to the vtec solenoid and make sure theirs no breaks in it "check with multimeter" and if you do the vtec light mod, then thatll let you know if the ecu is engauging the vtec or not. and the main relay isnt wired with the vtec or has nothing to do with the vtec. if your main relay wasnt functional then your car wouldnt start at all...
Old Sep 6, 2011 | 08:19 AM
cj.crx.'s Avatar
with the vtec light i just tap into wire for the solenoid? n ground the light... and i just mentioned the relay cuz i kno it needs to be replaced soon. .. thanks for yo help glock
Old Sep 6, 2011 | 08:27 AM
turbohatchBnuts's Avatar
Is your speedometer hookup?
Old Sep 6, 2011 | 08:44 AM
eg6bpd's Avatar
check all your sensors
Old Sep 6, 2011 | 10:11 AM
For vtec to work on stock ecu it got be at operating temperture (warmed up), got to have vss signal, good oil pressure, and rpms high enough when vtec engages.
Old Sep 6, 2011 | 10:43 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
He says he doesn't have a CEL... OP are you sure your red LED isn't flashing?
Old Sep 6, 2011 | 03:54 PM
Kron1116's Avatar
are you low on oil?
Old Sep 6, 2011 | 04:03 PM
4drEF's Avatar
Keyboard Humorist
Originally Posted by Kron1116
are you low on oil?
From first post.
Originally Posted by cj.crx.
oil is good
Old Sep 6, 2011 | 04:04 PM
4drEF's Avatar
Keyboard Humorist
Anything odd about the engine, like 'no thermostat'??
Old Sep 6, 2011 | 04:42 PM
How hot does your engine get? Does it stay close to the cold mark or half way between hot and cold.
rsfire
Engine Management and Tuning
Oct 28, 2017 06:27 AM
swizz977
10
May 25, 2011 08:15 PM
vtieg6
Nov 7, 2009 08:16 PM
tuckin15s_8315
Sep 28, 2005 09:35 PM
